runkos Posted August 25, 2012 Share Posted August 25, 2012 Wrecking R33 1995 Most parts available other then duck tail , ebc, and diff. Racing logic Ultra Complex Coilovers 12kg F 10Kg Rear $800 Lenso 18x9.5 +12 Fronts Bald Rears New tyres $1200 Greddy Turbo timer $50 Speco Boost Guage $35 Alloy Radiator $100 Front mount kit black paint ruff on cooler $ 180 Rb25det long motor comp tested all with in 3 psi of each other. New Cam cover seals $1100 Rb25det Gearbox bit of grey stuff in oil when drained but drove fine no crunching etc $950 Du luck side skirts $165 Rear Pods $ 85 Rear Bar $80 5 stud conversion $700 Nismo Strut brace $160 Front guards have zip tie holes drilled $ 60 each Front seats $90 Rears $45 Interior plastics From $ 10 just ask Alternator $90 Ps Pump $90 Air compressor $85 Clutch Fan $ 70 Cluster $85 Carpet $ 50 Catch can $20 Coil packs $15 each Engine loom $165 Ecu $100 Turbo and manifold $280 Split dump pipe $85 Front pipe 3 inch mild steel $ 75 Cat back 3 inch mild steel $ 165 includes cat Suspension arms from $30 just ask Seat belts $100 front pair Rears $70 the the lot Stock bov with pipe $60 Stock Injectors and rail $ 150 Fuel Tank $250 Headlights $250 Taillights $120 Ps rack $100 Dash pad $80 Fuse box loom $150 Rear Subframe $165 Front crossmember $100 Door trims $50 each Door handles $25each Window regs $85 each Power window switch drivers $85 Passanger $45 Window glass $75 each Door skins $65 each Anything else just ask. I can freight Australia wide Calll sms or email Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/ Share on other sites More sharing options...
rb2534 Posted August 25, 2012 Share Posted August 25, 2012 Location? Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6503443 Share on other sites More sharing options...
Nathan.J Posted August 25, 2012 Share Posted August 25, 2012 Do you have a pic of the Greddy turbo timer? Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6503493 Share on other sites More sharing options...
runkos Posted August 25, 2012 Author Share Posted August 25, 2012 Newcastle Nsw More pics up monday Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6503502 Share on other sites More sharing options...
Willis Posted August 26, 2012 Share Posted August 26, 2012 Comp figures of the engine? What power was it making.. for how long? How many k's? Stock? ^_^ Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6503666 Share on other sites More sharing options...
W0rp3D Posted August 26, 2012 Share Posted August 26, 2012 Location? if not in vic metro how much for fmic posted to 3200 Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6504177 Share on other sites More sharing options...
runkos Posted August 26, 2012 Author Share Posted August 26, 2012 Location? if not in vic metro how much for fmic posted to 3200 Ill get a quote tomorrow but id say you will be looking at around $70ish. Im in Newcastle nsw. I could be wrong the couriers ive been using are pretty good with price. Comp figures of the engine? What power was it making.. for how long? How many k's? Stock? ^_^ Comp was 118-121psi tested cold with my screw in comp test gauge. Car has 138000kms on it . Only mods are Exhaust and intercooler running 10psi Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6504300 Share on other sites More sharing options...
Tuscani Posted August 26, 2012 Share Posted August 26, 2012 Could you send me a pic of the alloy rad and postage quote to 4118 Thanks Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6504373 Share on other sites More sharing options...
Hot33r8723 Posted August 27, 2012 Share Posted August 27, 2012 I Need the electric Ariel 0421854393 Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6504790 Share on other sites More sharing options...
Pezhead Posted August 27, 2012 Share Posted August 27, 2012 Do you have the plastic that goes across the back of the boot interior that hides the tail lights? I'm interested in that cause my plastic is all broken. Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6505355 Share on other sites More sharing options...
runkos Posted August 27, 2012 Author Share Posted August 27, 2012 Postage to 4118 is $80 Pezhead i do have that trim send me a pm A few more pics from today. cheap dash has glue residue otherwise good conditon $50 Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6505744 Share on other sites More sharing options...
mitch w Posted August 27, 2012 Share Posted August 27, 2012 keen on the coilpacks s2 or 1i got a mate in newy that can pick up..... stock? Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6505837 Share on other sites More sharing options...
Beau.r Posted August 27, 2012 Share Posted August 27, 2012 quote for rear wing to 7015 thank you (no boot) Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6505995 Share on other sites More sharing options...
moronoto Posted August 27, 2012 Share Posted August 27, 2012 Hi I'm interesting rear bar it's that from factory? I'm in WA how much for all mate 0401370648 thx Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6506001 Share on other sites More sharing options...
runkos Posted August 28, 2012 Author Share Posted August 28, 2012 keen on the coilpacks s2 or 1i got a mate in newy that can pick up..... stock? Hi Removed from a series 2 engine quote for rear wing to 7015 thank you (no boot) Sorry Bud sold Hi I'm interesting rear bar it's that from factory? I'm in WA how much for all mate 0401370648 thx Hi mate freight to you is really expensive. Its a stock rear bar with pods on the side which are extra.I gave a quote today for a guy in Perth and a front bar from here to perth was $440. Way too much but i cant find any couriers that will do better prices on stuff to wa Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6507446 Share on other sites More sharing options...
runkos Posted August 28, 2012 Author Share Posted August 28, 2012 Bonnet Sold Coilovers sold Headlights sold Slave sold boot sold Silver dash plastic sold Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6507457 Share on other sites More sharing options...
Plattsy Posted August 29, 2012 Share Posted August 29, 2012 mate consider that catch can sold, can you do me a price plus postage to vic 3915? let me know how you want paying, bank transfer or pay pal easiest for me! Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6508538 Share on other sites More sharing options...
mitch w Posted August 29, 2012 Share Posted August 29, 2012 yea ill grab those packs $90 0423517539 cheers Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6508993 Share on other sites More sharing options...
mitch w Posted August 29, 2012 Share Posted August 29, 2012 you wouldnt happen to have those rubber rings frm top ov radiator?? Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6509003 Share on other sites More sharing options...
J N R Posted August 30, 2012 Share Posted August 30, 2012 Hey mate whats the radiator worth shipped to SA cheers and does it work with the standard radiator shroud and clutch fan? Link to comment https://www.sau.com.au/forums/topic/407814-dismantling-r33-gtst-1995-manual-coilovers-and-more/#findComment-6511093 Share on other sites More sharing options...
