Wrecking R33 1995
Most parts available other then duck tail , ebc, and diff.
Racing logic Ultra Complex Coilovers 12kg F 10Kg Rear $800
Lenso 18x9.5 +12 Fronts Bald Rears New tyres $1200
Greddy Turbo timer $50
Speco Boost Guage $35
Alloy Radiator $100
Front mount kit black paint ruff on cooler $ 180
Rb25det long motor comp tested all with in 3 psi of each other. New Cam cover seals $1100
Rb25det Gearbox bit of grey stuff in oil when drained but drove fine no crunching etc $950
Du luck side skirts $165
Rear Pods $ 85
Rear Bar $80
5 stud conversion $700
Nismo Strut brace $160
Front guards have zip tie holes drilled $ 60 each
Front seats $90
Rears $45
Interior plastics From $ 10 just ask
Alternator $90
Ps Pump $90
Air compressor $85
Clutch Fan $ 70
Cluster $85
Carpet $ 50
Catch can $20
Coil packs $15 each
Engine loom $165
Ecu $100
Turbo and manifold $280
Split dump pipe $85
Front pipe 3 inch mild steel $ 75
Cat back 3 inch mild steel $ 165 includes cat
Suspension arms from $30 just ask
Seat belts $100 front pair
Rears $70 the the lot
Stock bov with pipe $60
Stock Injectors and rail $ 150
Fuel Tank $250
Headlights $250
Taillights $120
Ps rack $100
Dash pad $80
Fuse box loom $150
Rear Subframe $165
Front crossmember $100
Door trims $50 each
Door handles $25each
Window regs $85 each
Power window switch drivers $85 Passanger $45
Window glass $75 each
Door skins $65 each
Anything else just ask.
I can freight Australia wide
Calll sms or email
post-90277-0-05272300-1345896912_thumb.jpgpost-90277-0-20867500-1345896667_thumb.jpgpost-90277-0-89216400-1345896627_thumb.jpgpost-90277-0-09706400-1345896645_thumb.jpg
Location? if not in vic metro how much for fmic posted to 3200
Ill get a quote tomorrow but id say you will be looking at around $70ish. Im in Newcastle nsw. I could be wrong the couriers ive been using are pretty good with price.
Comp figures of the engine? What power was it making.. for how long? How many k's? Stock? ^_^
Comp was 118-121psi tested cold with my screw in comp test gauge.
Car has 138000kms on it . Only mods are Exhaust and intercooler running 10psi
Do you have the plastic that goes across the back of the boot interior that hides the tail lights? I'm interested in that cause my plastic is all broken.
Postage to 4118 is $80
Pezhead i do have that trim send me a pm
A few more pics from today.
cheap dash has glue residue otherwise good conditon $50
keen on the coilpacks s2 or 1i got a mate in newy that can pick up..... stock?
Hi Removed from a series 2 engine
quote for rear wing to 7015 thank you (no boot)
Sorry Bud sold
Hi I'm interesting rear bar it's that from factory? I'm in WA how much for all mate 0401370648 thx
Hi mate freight to you is really expensive. Its a stock rear bar with pods on the side which are extra.
I gave a quote today for a guy in Perth and a front bar from here to perth was $440. Way too much but i cant find any couriers that will do better prices on stuff to wa
mate consider that catch can sold, can you do me a price plus postage to vic 3915? let me know how you want paying, bank transfer or pay pal easiest for me!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
