So I'm new here, and I can imagine its been covered before on this forum. But I can't find a straight forward answer.
The rear suspension in my R34 25GT has gone, and I can easily replace it for roughly $600, but I wanted to put adjustable coil overs in eventually any way, so that is what I'll be doing.
I was going to put Pedders Sports Ryder eXtreme XA Coil Over Suspension into it, But the bloke at Pedders seems to think they will fit onto the rears no problems, but might not fit onto the front for some reason.
Also he is doing a really crap job at getting back to me with an answer, which is why I'm asking here.
Now, I can buy a full set of these for $1520, what I want to know is, will these fit onto my car? (year is 1999 in case that makes a difference) Or is there a better product I can put on there in the same price range? (Can't spend anymore than $1600)
I know I can put on normal suspension for cheaper and it might be better quality, but I'll be putting on a body kit and new rims in less then a year (hopefully) and I don't want to have to change the springs again when this happens, which is a good reason why I want them to be adjustable.
Any help would be appreciated, Thanks in advance
https://www.sau.com.au/forums/topic/407838-r34-coil-over/
Rears come in 2 sorts. Eye or fork lower mounts. Fronts are the same for all R33's & R34's regardless of variant. Tbh I would be going somewhere else and probably getting something a bit better than pedders. Entry level teins, Silk roads etc.
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6503885
Apparently I must have eye lower mounts, I'm not using my car for any sort of drift/racing so they don't have to be the best,
How much would it cost for tiens or silk roads? And are they adjustable coil overs?
I don't know much about cars in general so sorry if I sound like an idiot haha
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6503905
Okay, so I've looked over a couple of other forums posts, and I've narrowed down my search for my price range.
These are what I've come up with
http://www.pedders.com.au/products/52
http://www.isc-coilovers.com/coilovers.html
http://justjap.com/store/product.php?productid=18623&cat=422&page=9
http://justjap.com/store/product.php?productid=20209&cat=422&page=9
The last two are the same product I'm pretty sure. Its just that one is a fork type and the other is an eyelet type. I think the 1999 25GT has an eyelet type (If someone could clarify on that it would be great)
Could someone please tell me which of these would be the better one to buy? As I really want my car back on the road ASAP!
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6503962
I just had a quick look at the bottom of the suspension on my car, they have the eyelet connection on both front and back.. Which doesnt look like whats in the picture of this
http://justjap.com/s...&cat=422&page=9
Edited by MaccaD2191
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6503979
I put bcs in my 33 the other week. Seems to be going ok at the moment.
Get them from street to track. They'll be about $150 cheaper than justjap.
Exactly what i did :thumbsup:
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6504621
I've got Tein SS on my 34 now, the rears got noisy and collapsed, this is why i am trying the BC's :)
Why don't you get Fulcrum Suspensions in Queensland to rebuild them? TEINs are much better than BCs ;)
https://www.sau.com.au/forums/topic/407838-r34-coil-over/#findComment-6505245
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
