:O I couldn't find any where else to buy bc coilovers, I just bought them from just jap, which was 200 more than street to track :/
But it was still cheaper than my original plan of going with the pedders. I was looking at the tiens. But they are a bit out of my price range sadly.
I've been having a look at a couple of tutorials on how to change / install coilovers, does anyone know how difficult it really is? Or if they would recommend someone that hasn't done it before doing it?
Why don't you get Fulcrum Suspensions in Queensland to rebuild them? TEINs are much better than BCs ;)
Yeah gunna sell them so someone else can do that and enjoy them... I am making my suspension all black to suit my whole build, and the green stands out way top much lol
Fk'n lawl! Fair call.
It's piss easy mate. Just pulled mine back out so I can clean em up and remove helper springs before car goes back on the road. Took maybe an hourish by myself.
Rears:
1. Remove back seat(2 12mm bolts at the base either side, pull up and out then 2 on either corner below the top half)
2. Remove parcel shelf, pulls up and out.
3. Undo strut top nuts(2 12mm bolts either side under the parcel shelf)
4. Loosen off wheel nuts, jack up car under diff. Lower car onto stands.
5. Crack the lower strut nuts, 17mm. Will most likely require a decent length breaker or a breaker with a length of pipe over the end especially if they've never been removed before.
6. Pull bottom mount off hub(May need a screwdriver etc between hub and shock if it's tight). Shock will then drop down.
7. Install in reverse order.
Fronts
1. Open bonnet, undo strut top nuts, (2x 14mm either side)
2. Loosen wheel nuts, jack car up at front, (I usually use the engine crossmember or if the cars too low the tow hooks under the front bar) Lower onto stands.
3. Crack lower nuts, 17mm again. Will generally require similar force to the rears.
4. Loosen off same as rears.
5. Assemble in reverse order.
the first time you go to put them in will take you around 1.5 hours. some advice, on the fronts the urethane bush at the bottom has the longer side facing the upright (metal ring on longer side as well) and the torque specs are 75nm for the bottom bolts and 40nm for the tops. other than that follow the above steps, check your height before to know how far your going to lower it and it should be to hard at all :)
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
