:O I couldn't find any where else to buy bc coilovers, I just bought them from just jap, which was 200 more than street to track :/
But it was still cheaper than my original plan of going with the pedders. I was looking at the tiens. But they are a bit out of my price range sadly.
I've been having a look at a couple of tutorials on how to change / install coilovers, does anyone know how difficult it really is? Or if they would recommend someone that hasn't done it before doing it?
  On 27/08/2012 at 6:59 AM, Hank Scorpio said:
Why don't you get Fulcrum Suspensions in Queensland to rebuild them? TEINs are much better than BCs ;)
Yeah gunna sell them so someone else can do that and enjoy them... I am making my suspension all black to suit my whole build, and the green stands out way top much lol
Fk'n lawl! Fair call.
It's piss easy mate. Just pulled mine back out so I can clean em up and remove helper springs before car goes back on the road. Took maybe an hourish by myself.
Rears:
1. Remove back seat(2 12mm bolts at the base either side, pull up and out then 2 on either corner below the top half)
2. Remove parcel shelf, pulls up and out.
3. Undo strut top nuts(2 12mm bolts either side under the parcel shelf)
4. Loosen off wheel nuts, jack up car under diff. Lower car onto stands.
5. Crack the lower strut nuts, 17mm. Will most likely require a decent length breaker or a breaker with a length of pipe over the end especially if they've never been removed before.
6. Pull bottom mount off hub(May need a screwdriver etc between hub and shock if it's tight). Shock will then drop down.
7. Install in reverse order.
Fronts
1. Open bonnet, undo strut top nuts, (2x 14mm either side)
2. Loosen wheel nuts, jack car up at front, (I usually use the engine crossmember or if the cars too low the tow hooks under the front bar) Lower onto stands.
3. Crack lower nuts, 17mm again. Will generally require similar force to the rears.
4. Loosen off same as rears.
5. Assemble in reverse order.
the first time you go to put them in will take you around 1.5 hours. some advice, on the fronts the urethane bush at the bottom has the longer side facing the upright (metal ring on longer side as well) and the torque specs are 75nm for the bottom bolts and 40nm for the tops. other than that follow the above steps, check your height before to know how far your going to lower it and it should be to hard at all :)
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
