Hi guys I'm pretty sure I need to rebuild it but I thought it worth asking the question. Last week I was about to race at Sydney dragway but I thought maybe I should do a compression test as I hadn't done one since fitting turbos. Cyl 1 to 5 were 150psi and #6 was 100psi wet or dry, the engine had been run that day but wasn't at operating temp. It doesn't use oil and still goes as good as it did at the skyline drag day where it ran 12.1 at 118mph. So I'm wondering if there is another test? I disconnected the cas and turned it over to listen for any difference while cranking but it sounded the same on each cylinder. Before I changed turbos I also attended a Wednesday night where the coil packs gave up and that's the only time I can think of anything actually going wrong with the car, but since then it's been dyno tuned and done at least 10 passes, is that possible with one cylinder 50psi down? Or am I just clutching at straws and need to rebuild it ?
Scott
https://www.sau.com.au/forums/topic/407845-rb26-compression-question/
  • 3 months later...
Hi guys just a quick update I decided to do hot compression test to see if there was any improvement and I did #5 and got 145 and #6 and got just over 140 with both I did for above 10 secs on starter I didn't bother checking the others as previously on the cold test they were even, so what does this mean? I'm looking at installing my -5s and 1000cc injectors and e85 but I don't want to waste time if the engine needs to come out, any opinions are appreciated. Scott
Hot dry test 145 and 140psi? Seems like a tired engine....boost it up should be right ! Haha
if he had some aftermarket cams, 140psi might be perfectly normal, and now there close in comparison compared to the original 50psi difference in number 6, and doing 12 second quarters it must be pretty healthy..
If your worried its the cam timing, mark where the cams are ATM. Than move them both back to 0 test the comp and see if there's a diffrence.
Than just set the cams back to the marks you made before you drive the car again.
Sorry I meant cam gear adjustment it has hks gears and its never been changed since it was tuned more than a year ago so I have no reason to think that has anything to do with it, it has 290kw at the rears but was limited due to afms still being stock but he said it made the power very easily,
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
