Parting out an accident damaged 1995 33 gtr with some aftermarket parts.
No engine, brakes or front seats. Front end damage so no front body panels.
Parts are located in Ipswich qld and I can be contacted via ph. 0413863207 or pm on this forum.
Pickup is available and payment is by cash or postal money order. I do NOT do bank transfer or paypal so please dont ask.
Condition of parts is as described.
Pics.
Aragosta coilovers. these are top shelf coilovers, condition is very good with just cosmetic marks from road blast. No leaks or knocks......$1750.00
post-35087-0-55797600-1345957291_thumb.jpg33gtr gearbox complete with shifter and cross member. Good working condition...$650
Nismo white face dash cluster and triple centre guages, dash cluster is mint with low kays, centre guage are in excellent condition with just a broken corner on a mounting tab. has zero effect on the guage and can not be seen when installed. $650.00 the pair
Genuine C's short shifter with heavy throw shift knob, excellent condition...$175.00
Walbro in tank fuel pump wired and ready to clip straight in, perfect condition...$150.00
Genuine Nismo clear indicators with bulbs. perfect condition....$40.00 ther pair
post-35087-0-75649700-1345957487_thumb.jpgWhiteline front sway bar with adjustable links in excellent condition...$200.00
Genuine nissan gtr rear strut brace in excellent condition with mounting brackets..$100.00
Nismo brake lines for gtr, front and rear in very good condition...$150.00
HKS priest stainless exhaust with cat and will throw in front pipes, system is in great condition with just road wear $450.00
Genuine 33 gtr rear wing with carbon end caps. very good condition, paint is not factory..$350.00
Genuine gtr 2 piece side skirts in very good condition, a few scrapes along the bottom but no damage..$150.00
GTR front drive shaft in good coondition...$100.00
Genuine 33 gtr rear sway bar, good upb
grade for 33 gtst..$50.00
Dual A pillar pod mount..$50.00
steering column surround..$25.00
Passenger kick panel...$15.00
GTR bovs on genuine gtr pipe...125.00
BM 57 33gtr brake master cylinder..$75.00
33gtr clutch slabe..$50.00
33 gtr power steering reservoir..$50.00
33 gtr ABS unit..$250.00
33 gtr injector resistor pack,,$75.00
33GTR buar raisers...$100.00
33 GTR bonnet hinges..$50.00
Drivers side window switches (2) ..$100.00 each
Custom washer bottle catch can combo in polished alloy..$125.00
33 GTR door cards front and rear really good condition with one small blemish on passenger door (see pic)..$150.00
Front passenger guard with a couple of very small dents, easily repairable..$75.00
GTR sump with Cusco 1.5 way diff. Diff is near new, Sump has a hairline crack but will be repaired prior to sale..$650.00
33gtr power steering Wrack in very good condition...$100.00
Complete 33 GTR kaframe with Vspec diff, all arms knuckles and handbrakes. $650.00
GTR centre console cup holder with GTR badge..$25.00
post-35087-0-21341800-1345957848_thumb.jpgpost-35087-0-47272900-1345957861_thumb.jpgpost-35087-0-87899600-1345957879_thumb.jpg
AS new Jim berry full monty clutch and pressure plate. This clutch has done less than 2 hours work and all machine marks are still visible, Would definitely suit new buyer..$800.00
Other items without pics..full set of front and rear prince mats in very good nick...$100.00
Attessa pump..$200.00
Genuine facory rear bar in excellent condition..$150.00
Larger items are pickup, Most items I will post at buyers expense.
Should you require any other info please contact me.
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/
Hi, Would you have the sub loom for the 2 knock sensosr,idling control, oil temp etc. that end up with a grey 8 pin plug onto the plug in the front part of the fuel rail?
Thanks
Alex 0433878905
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/#findComment-6531969
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
