Parting out an accident damaged 1995 33 gtr with some aftermarket parts.
No engine, brakes or front seats. Front end damage so no front body panels.
Parts are located in Ipswich qld and I can be contacted via ph. 0413863207 or pm on this forum.
Pickup is available and payment is by cash or postal money order. I do NOT do bank transfer or paypal so please dont ask.
Condition of parts is as described.
Pics.
Aragosta coilovers. these are top shelf coilovers, condition is very good with just cosmetic marks from road blast. No leaks or knocks......$1750.00
post-35087-0-55797600-1345957291_thumb.jpg33gtr gearbox complete with shifter and cross member. Good working condition...$650
Nismo white face dash cluster and triple centre guages, dash cluster is mint with low kays, centre guage are in excellent condition with just a broken corner on a mounting tab. has zero effect on the guage and can not be seen when installed. $650.00 the pair
Genuine C's short shifter with heavy throw shift knob, excellent condition...$175.00
Walbro in tank fuel pump wired and ready to clip straight in, perfect condition...$150.00
Genuine Nismo clear indicators with bulbs. perfect condition....$40.00 ther pair
post-35087-0-75649700-1345957487_thumb.jpgWhiteline front sway bar with adjustable links in excellent condition...$200.00
Genuine nissan gtr rear strut brace in excellent condition with mounting brackets..$100.00
Nismo brake lines for gtr, front and rear in very good condition...$150.00
HKS priest stainless exhaust with cat and will throw in front pipes, system is in great condition with just road wear $450.00
Genuine 33 gtr rear wing with carbon end caps. very good condition, paint is not factory..$350.00
Genuine gtr 2 piece side skirts in very good condition, a few scrapes along the bottom but no damage..$150.00
GTR front drive shaft in good coondition...$100.00
Genuine 33 gtr rear sway bar, good upb
grade for 33 gtst..$50.00
Dual A pillar pod mount..$50.00
steering column surround..$25.00
Passenger kick panel...$15.00
GTR bovs on genuine gtr pipe...125.00
BM 57 33gtr brake master cylinder..$75.00
33gtr clutch slabe..$50.00
33 gtr power steering reservoir..$50.00
33 gtr ABS unit..$250.00
33 gtr injector resistor pack,,$75.00
33GTR buar raisers...$100.00
33 GTR bonnet hinges..$50.00
Drivers side window switches (2) ..$100.00 each
Custom washer bottle catch can combo in polished alloy..$125.00
33 GTR door cards front and rear really good condition with one small blemish on passenger door (see pic)..$150.00
Front passenger guard with a couple of very small dents, easily repairable..$75.00
GTR sump with Cusco 1.5 way diff. Diff is near new, Sump has a hairline crack but will be repaired prior to sale..$650.00
33gtr power steering Wrack in very good condition...$100.00
Complete 33 GTR kaframe with Vspec diff, all arms knuckles and handbrakes. $650.00
GTR centre console cup holder with GTR badge..$25.00
post-35087-0-21341800-1345957848_thumb.jpgpost-35087-0-47272900-1345957861_thumb.jpgpost-35087-0-87899600-1345957879_thumb.jpg
AS new Jim berry full monty clutch and pressure plate. This clutch has done less than 2 hours work and all machine marks are still visible, Would definitely suit new buyer..$800.00
Other items without pics..full set of front and rear prince mats in very good nick...$100.00
Attessa pump..$200.00
Genuine facory rear bar in excellent condition..$150.00
Larger items are pickup, Most items I will post at buyers expense.
Should you require any other info please contact me.
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/
Hi, Would you have the sub loom for the 2 knock sensosr,idling control, oil temp etc. that end up with a grey 8 pin plug onto the plug in the front part of the fuel rail?
Thanks
Alex 0433878905
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/#findComment-6531969
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
