Hey guys my beloved r33 got stolen right from my drive way :/
so this vehicle is stolen and recovered (classified as repairable write-off)
the reg is still active at this stage in case some one wants to fix and drive it.
The ignition barrel and drivers window are broken and engine seems to have a blown head gasket.
turbo is missing the turbine wheel i think its in the cat ... lol
there is minor damage just behind the drivers door but looks like a easy fix
The vehicle is still a whole and stock so let me know what parts your after and ill price it up
wheels are not for sale and exhaust.
located in northern suburbs
Thankyou for reading pics up soon
Edited by xm4tr1x
https://www.sau.com.au/forums/topic/407860-vic-wrecking-white-r33-gts-t/
  • Replies 60
Posted Images
Hey mate im interested in buying ur front bar, lights, guard lhs, rear bar and side skirts, i also live in northern suburbs and ready to buy i price is right, please call me or msg me on 0413 556 178, my name is kay, or giv me ur details and i can call u
Rb25det Gearbox drove fine no crunching etc $1000
Front Bar $ 200 pending payment
Rear Bar $100 pending payment
Front LHS quarter $100
Front RHS quarter $100 pending payment
Series 2Headlights $250 pending payment
Front seats $90
Rears $45
Interior plastics From $ 10 just ask
Alternator $90
Ps Pump $90
Aircon compressor $85
Clutch Fan $ 70
Cluster $100
Carpet $ 200
Coil packs $20 each
Engine loom $165
Ecu $100
Suspension arms from $30 just ask
Seat belts $100 front pair
Stock bov with pipe $60 pending payment
Stock Injectors and rail $ 150
Fuel Tank $250
Headlights $250 - pending payment
Taillights $120
Ps rack $100
Dash pad $80
Fuse box loom $150
Rear Subframe $165
Front crossmember $100
Door trims $50 each
Door handles $25each
Window regs $85 each
Power window switch drivers $85 Passanger $45
Window glass $75 each
Door skins $65 each
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
