hi
i have for sale a set of 18" super advan wheels with near new tires
fronts - 18" x 8.5" - tires - 235 x 40 x 18 (front right is brand new, front left is around 75 - 80% tread)
rears - 18" x 9.5" - tires - 265 x 35 x 18 (only done 3000k's on them - 75 - 80% tread left)
i have the original centre spanner and wheel nuts aswell
asking $1200 ono
call or text mitch on 0424 143 184, or pm me here
located in budgewoi NSW (central coast)
can deliver to sydney or newcastle, or can arrange postage to any other state if need be. and here's a few pics
PLEASE NOTE: these are off a 300zx but should fit a skyline pretty well and clear the calipers, unsure of the offset tho.
front right (still have the original spanner for undoing the centers as you can see)
front left
front tread
right rear
left rear
rear tread
and a couple on the car
cheers
mitch
ps. any offer considered, as i need these gone.
Edited by weeman1
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
