Hi All,
I was bored on the weekend (actually let's say feeling productive), and I recently acquired this cheap amp for $20 and needed to mount it somewhere out of the way. Instead of mounting it under the seat like some, I decided to make use of the space between the fuel pump access point and the HICAS crap.
Note: This only applies to R33 Coupes.
I reused the stock fuse block bolt holes, one thing to notice, there's a tab on the rear side of the block that needs to be trimmed/snapped off in order to allow the plate to sit flush.
Other than that, the photos should speak a thousand words.
Final note, I've previously found that mounting the amp there, next to all the power lines, etc. 'may' cause some noise, but when I replaced it with better RCAs the noise went away. In the past, I've used 2x Z like alloy brackets I made using a flat piece of alloy. Too much drilling involved, this method requires you to only drill 1 or 2 holes. I went for 2x because of that odd looking bracket I found.
Nice work, do you have the dimensions for the amp? The Kenwood amp I had in my last r33 would not fit in there.
Edit: found the amp at the Kenwood site Size [mm] : 330[W] x 59[H] x 227.26[D]
Edited by pfcr33
Are you sure?
It does the job for giving a bit of extra sub bass. Given that the car has enough road noise despite sound deadening in doors and under the rear seat/wheel arches you have to accept the car is flawed for getting great sound.
This is good enough for my needs but clearly not perfect or ideal.
  On 11/09/2012 at 2:27 AM, Carbon 34 said:
Perfect for blowing the cone out of that rear speaker !!
his rear speaker cones still seem to be intact
How can you tell from that photo unless it was shot clear the fark out you wouldnt know ?
they will without any doubt distort when turned up and eventually blow the cone past the voice coil gap by the air pressure firing into the underside In turn it frys the speaker , sometimes instant sometimes slow death depnding on the pressure wave , they do make soft foam inserts to stop it or you can make some easy enough
Ive been doing this since before your birth prob so dont bother with your theory rants Mate
I'm sure if his speakers were blown he would know and that he would have noted that too.
That's great you've been doing since my birth.
Your such a muppet "wanna be smart ass" good to know your the audio "GOD " I'd better stop posting cause you know it all !!! let me bow down to you
Why bother being informative to anyone like you ? Disrespectful ass
when did I say I was a god? when I have I recommended anything to anyone?
cool story
you're my hero man
so quick to tell everyone how long you have been doing this
every thread you have posted in that I have seen you get aggro
cawk
    • Where is the electrical conduit? 馃ぃ馃ぃ
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
