Ring as many as you can find and decide for yourself. Its best you try to find a tuner that YOU LIKE, not because people on a forum say he is the best. First place to start is ask the people who service your car. Or better yet join a car club, go to some events and speak to people first hand and look at people who have similar mods to yourself. On forums you can only get positive comments so only ever use as a guide of where to start looking
  • Replies 46
Popular Days
Posted Images
Well put Roy.The problem with forums you only get good feedback.I would never name and shame the tuner that screwed me over(not over the internet anyhow)as maybe he was good for someone else.Defamation is a big thing.Like everything in life,check things out and look around.
Edited by mattie4270
Thread closed.
Have a search perhaps next time - easy to find answers to common questions.
Dude I've already been nice & given you a hint to stop the off topic dribble in tech areas.
Next time you'll get a long holiday - stop it.
Guest
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
