Willall Transmission Oil? Diff Oil? Thoughts?
jona1986
 Share
I am recently thinking to use Willall oil for my major service.
However my friend is talking me into not using it because he knows people who have a sensor fail in the gearbox after using Willall oil.
He also said that Willall oil causes the rear LSD to have excessive noice.
Has anyone experienced these? Or fine in a long run after using Willall oils?
Please advise whether it is good to go ahead or not.
Thanks
Well thats easy. Take what your 'friend' told you, invert it, and theres your answer.
I wont go on about it, I will let those that have spent their own hard earned give their own real world experiences :)
Well I have done a bit of read up and most people seem to be happy with the WR oil apart from the warranty issue. I am still leaning towards using Willall oil after hearing what my friend has told me. However since I am new to the GTR world so thats why I am asking it here...
I am running Willall trans oil and have no issues. I have Willall diff oil sittng in the garage ready to go in as well. Martin has top quality products and his willingness to help out over the phone is awesome.
I will most likely be moving to the Willall transmission fluid after my warranty runs out.
My GTR tech is against it but I have heard good things about it.
I am currently on OEM. I am also getting my transmission fixed under warranty in a few weeks. It was already a bit of a battle with getting the warranty approved on OEM fluids (consisted of multiple visits to the HPC, sound and video clips, complaints to Nissan Australia etc). I do not if I would have had the same outcome if I was on Willall though?
Could you elaborate what the symptons of your tranny were?
Loud rattle (sounds like marbles) during acceleration from standstill or slow speeds (between 900-1300 rpm). At idle, there is rattling but it's the 'normal' rattling and nothing like the ones in NAGTROC. There are no noises in park/neutral revving.
Gets annoying/embarrasing when I am in start/stop traffic or parking and I need to step on the accelerator often as the rattle appears.
Currently, there is prop shaft play but within tolerance. Noise appeared a month ago and getting louder. Have done 0 launches.
Ecl, sounds like your bell-housing needs fixing.
Have your Nissan 'tech' unbolt the prop-shaft from the back of it, then check the freeplay - it will be excessive
Martin, are you aware of the same bellhousing issue with the 2010's and beyond?
I have the usual rattles as well, and while stationary in gear only a very very slight rattle when the car is hot, but nothing noticeable above 2000rpms. Of course in P or N after the car is stationary and hot parked in my garage after a run, the rattle is fairly noisy, but not excessive like some youtube vids. I am however hearing a very very very faint higher pitched rattle somewhere in the back while driving @ 60+ kph on fairly smooth roads though (definitely not the brake pad rattle) - not sure if this is the seat belt housing issue others have experienced, or something else under the car. The Nissan tech mentioned it at the last service and said to keep an ear on it if it gets any louder they'll investigate further. Its not loud though, and certainly hasn't increased in volume - for all I know its probably just the fly wheel and normal sounds. My GTR has also had 0 launches (that I know of :P), so not currently too worried about it.
Edited by Wardski
I hate the brake pad rattle, and get embarrassed when travelling thru the brisbane city and run over 10 bazzillion bumps in the road I can hear the clanging noise echo off the buildings.... farks sake..
Edited by Wardski
Yeah, that is bad as well. I drive on the motorway where is basically a wall on one side and construction happening. I get to hear the rattle pretty much every day =(
Martin - yeah, Nissan is offering the replacement so it's all good =) hopefully they give me the newer model bellhousing. The dealer said they only have 1 part number that they order from. Also, they can now do it without dropping the engine.
Thanks
I'm running all Willall fluids in an Alpha 12 setup that puts out significantly more power than stock. No issues at all at his end. I think your friend is relying on a lot of heresay and has not used the Willall fluids. Make the change, you won't be dissapointed.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
