Can anyone tell me what size is best for turbo, as in rear housing size for compressor and turbine sides? Im chasing about 230kw on a rb20 with all the supporting mods tune etc, here at the details of the turbo i want
Compressor
Ind wheel dia 53mm
Exd wheel dia 76mm
Trim 55
A/R i can choose from 0.5 or 0.6 what is best?
Turbine
Whl dia 53mm
Trim 76
A/R 0.64
If anyone could tell me what this would be like as in laggy or anything that would be great!
https://www.sau.com.au/forums/topic/407959-turbo-size/
  • Replies 42
The bigger the number the less lag :blink:
have you happened to stumble upon this?
http://www.skylinesaustralia.com/forums/topic/103095-rb20-turbo-upgrade-all-dyno-results/
What number do u mean to have less lag?
Its a turbo off ebay but its not cheap its $1200
https://www.sau.com.au/forums/topic/407959-turbo-size/#findComment-6505563
I agree Ebay special, STAY AWAY. I can guarantee it will be a laggy piece of shit.
The answer is: http://www.skylinesaustralia.com/forums/topic/103095-rb20-turbo-upgrade-all-dyno-results/
Get a RB25 stock turbo (maybe ones that already highflowed) and hiflow it (check hypergear). It will be superior (response and power) to that chinese piece of shit you linked.
https://www.sau.com.au/forums/topic/407959-turbo-size/#findComment-6506075
Stay away or prepare to have laid down $1250 for a shiny paper weight.
If your happy to spend that sort of money.
Get an RB25 turbo high flowed by hyper gear. Similar cost, will make well over 230kW, no where near as laggy and looks factory.
https://www.sau.com.au/forums/topic/407959-turbo-size/#findComment-6506083
that KLS power spirit mob can go shove it up their ass. bought an oil cooler kit from them the other week. ive paid less for much higher quality things from china before, but this was just ghastly what they sent me. currently getting a refund.
$1250 lol the cheeky bastards.
https://www.sau.com.au/forums/topic/407959-turbo-size/#findComment-6506108
Haha thanks for the feedback guys ill steer away from them! Pretty expensive for chinese brand! I have heard that high flowing a 25 turbo can be laggy? Not to sure havnt really looked into to it much? Anyone got one on there car and no if its laggy? My other option is going a hks 2530
https://www.sau.com.au/forums/topic/407959-turbo-size/#findComment-6506887
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
