I'm no mech but I'd get it replaced.
From what I can see, there seems to be a hairline crack from somewhat in the middle of the crack where the chip is, leading towards the right side. As you drive, the roads, speed bumps, holes etc. anything that will cause vibration will cause the crack to grow and eventually break off. Given that it pulls the belts, you can imagine what would happen if something hit it and bent it out of line. Could shave off your belts or worse case scenario, the piece breaks off completely, gets flicked up into the belts, causing more damage to other parts.
This is from my point of view, a crack like that, I'd get it replaced when I can. Fork out some money to replace this than forking out 4 times more replacing other bits that this has caused.
Just my 2c.
I may be completely wrong though.
That's the term I was looking for. Couldn't put my finger on it so it came out in 100+ words.
No worries Ricky :) - you were quite explicit.
I'm used to my wife coming out with a 20 page thesis hehe...
Nah mate I wouldn't bother that's not gonna do anything when the crank shaft is spinning there's enough vibration in I already a little chip like that won't do jack all I'm sorry i won't full stop and u know how I no cos I ran a balancer like that for years pulled out my crank and everything was fine and it was 20 times as worse condition Ull be fine mate take the advice it will be fine
Edited by Hot33r8723
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
