Hey guys long story short i have changed my radiator , thermostat , radiator hoses , radiator cap and water pump and since then my overflow bottle has gone bone dry 2 times and im freaking out as i have checked my oil cap and its not milky and the fact that i have basically changed the whole cooling system and this is happening.
has anyone else had this same problem or know what it could be cos from what iv seen i cant see any coolant leaking.
last time i filled it up when the overflow went empty, now yesterday the coolant had about 2 fingers left in the bottle and i had a looktoday and there is nothing left then i went filled petrol and have not checked the radiator yet
long story short i bought this car and it sat for 1 year as i was still on my ps and when i was getting a power steering belt changed i later on realised something must of hit the standard radiator and there was a hole so i swapped it out for a just jap one. upon getting my fulls i got it tuned there was a hairline crack in the water pump so that was swapped out and i thought id might as well do the thermostat as the rest of the cooling system was new
hey you bleed the cooling system of air... it could be just bleeding the air from the system and using the coolant from the overflow like it should.
cheers sam
system was bled and filled up after so i doubt it could be that.
If its not leaking on the ground then its probably going in a cylinder,most probably a head gasket.Check the spark plugs,if ones a bit chalky then thats the cylinder
coming to think of it i have had a really bad misfiring on idle so i will def give the spark plugs a check tomorrow
Could be air still working itself through the system keep on filling up and hope it stops, give it 5 more cold start-ups to be sure.
This happened to me, more then twice when i went for a drive checked the coolant in the morning and nothing was in the overflow
turned out my radiator cap was shot and no pressure was in my hoses (check for pressure in yours) changed it and 2-3 times after that it did the same
thing just not as bad and i just kept on feeling her up until coolant stayed. I reckon air still in the system ! i was afraid my head gasket or worse
cracked block was the problem, thank god it wasn't.
Edited by starwarz
poppedd in to my mechanics today he is leaning towards a air leak as when he put more fuel into the tune the car started to idle better.
so its going in next monday for a smoke test and a pressure test on the cooling system
thanks mate... this is the last thing i need now haha.. had car in lock up for a yr just watching it till i got my fulls and hopefully i dont need to watch it for another yr till i save $ to build the engine
It still needs bleeding there hard to bleed. I keep bleeding it then let it cool down and check overflow bottle until level stablizes takes close to 10 times til fully bled so nothing to worry about, either keep topping it up til it stops losing or bleed it.
Edited by boostn0199
  • 3 weeks later...
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
