Since you are new I will cut you a break, but please in future before posting a new thread use the search function - this topic has been covered dozens of time before.
Easiest way to do it is disconnect your battery and pump the brake pedal 10 times. Or leave the battery disconnected overnight.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506058
^^ this method did not work on my 2005 V35.. I am assuming the OP wants to clear the self learn data, which will need consult or a datascan tool (not sure if there is a manual procedure for this?)
Doubt you will notice any difference, unless a faulty sensor has been messing up the data previously.
maybe removing the battery works for earlier ECUs??
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506355
pv35gt8 he never mentioned anything about fault codes .... read the topic content before you post ....
And sonicii in my 03 coupe it most definitely does work - I can feel the difference and see the fuel economy difference when I reset my ECU. Why else would they tell you in the installation instructions of things like the Kinetix upper plenum to reset the ECU via this method after fitting the upper plenum to see results? Maybe the series II ECU is different, but I can't imagine for a second the cars auto tune saves to flash.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506392
It should work. It worked on my 2001 VQ25det Stagea and still works on my 2004 VQ35de Stagea (basically an AWD Series 2 V35... with a nicer nose/body :P).
Perhaps your timing was a little out. It can be easy to miss-time.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506398
You need to retrieve the fault codes and clear them before you initiate a relearn.
Simply disconnecting the battery and letting the system completely drain any residual power will not reset the ECU.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506547
Sorry, you managed to slip your last post in just before I hit send. I meant the disconnecting the battery method didn't work for me.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506730
It probably is a good idea to clear this data when making any significant changes. But I reset mine a couple of months back and reduced my fuel economy for a while.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506737
Where the hell is Suriname anyway?
South America, like North East. Google FTW. Was going to say "Hola", but then wiki says they speak Dutch :(
+1
You car doesn't magically lose its ECU coding when there isn't a battery connected, so it ain't going to lose the self learn. Pump zee pedal, or get a program that works, like Cipher.
https://www.sau.com.au/forums/topic/407984-ecu-reset/#findComment-6506753
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
