im in the process of gettn sum more power out of my r33 series s1 its currently making 210kw at 12psi,ive found a r34 hiflow turbo and sum 550cc denso injectors cheap.im just tryn to find out wat power it should make roughly?will it be heaps laggy compared to my stock turbo?and how much power and boost should i go for safely on a unopened engine?
i currently have:
fmic,3.5" exhaust turbo back , walbro fuel pump,turbosmart boost controller and gtr coilpacks with iridium plugs,still running stock air box with drift panel filter.
I run up to 20psi on my stock engine and its going fine.
Others have run even more of course but I wouldnt push it past 22psi as a high boost setting.
The R34 highflows are good to around 250rwkw give or take 10 or so kw depending on your engine, dyno, setup etc.
It wont be laggy and you should be able to push around 18psi or something through the highflow.
Once you get into these numbers you will need a aftermarket ECU + Z32 air flow meter.
I dont know how much your injectors flow either so you might need different ones?
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
