Morning gents.
I bought the missus a D90 kit 2yrs ago and she hasn't really taken to it. Granted she said she wanted to do a photography course and hasn't done so yet, meaning she really doesn't know how to drive the camera properly or get the best from it, but the big issue for her is she feel as though she misses the shot every time because the camera is too slow.
I've spent a bit of time with it so I at least know how to adjust aperture or shutter speed to use to get a reasonable photo where as she just wants to leave it on Auto and have it be magic, I told her that's not how it works... That said, I do agree with her that sometimes, the camera can take too long on finding its focal point and I've tried to beat it using manual focus or selecting the focal point in the viewfinder to help but it doesn't seem to do much better.
I understand that with a point and shoot it'll just take the shot anyway and be blurry, where as the D90 won't take the shot until it has focus, which can be frustrating when it's zooming in and out trying to find its range.
Is this a limitation of the camera? or the lenses? (18-55m and 70-200mm kit lenses). I'll admit I did drop the 18-55 once and the ring gear is slightly loose but the focal speed has always seemed to be an issue and the images are still crisp when it does find focus.
Can we just buy a faster focusing lens?
Thoughts?
Edited by ActionDan
https://www.sau.com.au/forums/topic/407997-focus-faster/
There's little focus points across the camera. like in the centre and a ring about half way around. in the menu you can turn on a display for these focus points if it's not up already.
ifyou want to focus fast put a high contrast area inside these little squares and it will lock on (Focus works on contrast for both light/dark and (nikon only colour contrasts too))
then hold the AE lock button and reframe shot if needed.
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6506558
I've got those points enabled and selecting between them is not an issue, my issue is more how long it takes the lens to focus. I'm assuming what you mean is focus on the point I think the shot will be at and be ready, but the what I'm trying to do is improve the time it takes the lens to perform its initial focus.
Even in well lit areas in doesn't seem quick. Is that likely to be a lens issue, camera issue, or just the behaviour of the system?
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6506561
to work out if its the camera or lenses a store or friend with a d90 would be handy. then you can compare bodies and lenses and try to work out if there is a hardware failure or not
Edited by Jay019
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6507455
Good idea. I've also been doing some reading on the AF system in the D90 to see what changes can be made to speed up the process, at the moment I think it's set to matrix metering and 3D focal points (or something to that affect) consensus seems to be that unless you are going for an artistic shot or a specific composition that you leave it to centre weighted and focused so I'll try that too.
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6507703
Keep it set on auto - wide.
that 3d tracking thing is f**king shit. so are all the other options for AF.
when i say focus on te contrast, i dont mean centre it on the centre of the red shirt your friend is wearing. if you want fast focus centre it on the edge of the shirt and the black background. find clear/sharp edges to lock on. then reframe. if it's a normal shot you won't have to, but if youre trying to get super quick focus on the fly, this is how you do it.
It's a pain in the arse and tricky to start with, but if it can be done with enough time to reframe shot on a car travelling 200kmh i'm sure it can be done under normal circumstances pretty easily.
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6507784
Hah, OK I'll have a fiddle and see what I can do. Camera might take a back seat for the moment though, car dramas take priority.
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6507788
  • 3 months later...
I've had a bit more of a play since this question, and found that for the type of pics I'm taking that auto-centre seems to be the quickest.
That said, I the standard 18-55mm kit lens has taken a beating and it wobbles a bit and I've noticed it will bind up a bit sometimes so realistically it should be replaced.
What's a good standard 18-55 or 18-70mm or so auto focus lens that's worth looking at?
https://www.sau.com.au/forums/topic/407997-focus-faster/#findComment-6648845
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
