Just did the same, immediately better on idle, but the car wasn't 100% cold so the real test will be when i get home and start her up tonight!
Will keep you all posted... oh i apparently have newish Denso pump (haven't checked) so hopefully running it 100% wont kill it.
Seems MUCH better at startup now, but i think i'll give the coil-packs a clean too...
  • 3 weeks later...
  • Replies 242
well, this is all very interesting!!!!
my R32 is doing all the same shit, pissing me off to the max..
cant be good . cause it does it , then i get mad and thrash the ****er out of it...
she is a t the doctors now getting a new..
1. timing belt
2. new plugs
3. fule filter
then after a day of them working on it they tell me it needs 2 new coil packs,NOOOOOOOOOO. just what i needed..
but i know thats not the problem,well maybe the rough idle but not the car dropping off at the lights
i turned up the revs on the AAC thing i think(the one at the back of the planom)
it holds the revs a bit better but it still drop too fast when ya jam the clutch in!! still shits its self.
still want to hard wire the fule pump, that is a great idea..
but i do want my fule guage to still work!! lol
WHAT WIRE IS THE ONE TO GROUND??????? this is the question of the day
please help
Further my sitch, finally took the centre cover off the other night and fired her up, nice little ligthenng show coming out of coils 1, 2, & 5. I have another complete set of coil-packs from my previous engine, swapped it over and the difference is night and day!
It still needs a little bit of gas at startup, but after that it idles no worries, i all also woound the idle screw on the back of the AAC housing out some as well.
Anyone had consistently sluggish WARM idle when starting? ie fires/starts OK when warm, but only idles at 550-600 rpm, slowly builds to 950 over about 5 sec or so. Only happens when warm and left for about 10-15 min or more. Can shut it down and restart straight away fine. All usual suspects ie AFM, O2 sensors have been checked, ACC valve resistance is about .7 ohms over spec but is clean etc and AC actuation causes no grief to idle speed.
Cold start no problem.
Thanks for any feedback.
Have you confirmed that the AAC valve is receiving a signal frm the ECU? I wouldn't worry about the .7 ohm difference to spec. When you turn the steering wheel and activate the power steering does the idle jump up? The AC idle speed is NOT controlled by the AAC but by the other valve directly next to it.
Hi Phantom;
Yes it does change idle speed when turning the wheel, I've witnessed this on a Snap On analyser similar to Consult
Hey scooby...these types of problems need monumental patience to solve....is your car stock or are there fuel/electric/ecu mods?
Another stab in the dark if you've run out of options.....fuel pumps in injected cars have a check valve that maintains pressure in the entire fuel system after shutdown for quite a while. Perhaps yours is bleeding away rapidly with time, or perhaps your fuel pump is worn and the leakage causes the fuel pressure to build slowly on start. Does the pump run for the usual few seconds prior to start? Maybe the cold start cycle with its different strategy is enough to disguise any issues in this mode. Is this a consistant repeatable problem or intermittent?
Yes they do
stock except exhaust
thought about this but a few things lead me to think it may not be related:
starts immediately when cold, rock solid idle
problem occured suddenly, didn't progress over time
have tried priming the pump and it makes no difference
Agreed
Constant and repeatable
thanks for the feedback phantom, I'll keep looking. no doubt one day it'll disappear and I still won't know what it was...I think something is either sluggish, stuck or not connecting well ie mechanical/electrical rather than fuel. there are only so many thing it could be, unfortunately it only appears for a few seconds each day and hence it's very hard to catch...hence your first point.
Regards
  • 1 month later...
ok guys... now i have this problem. sometime while driving my car just cuts out so smoothly that i didn't notice untill i accelerate... i have check the ACC, CAS and ignitiion signal from ecu they seem to be ok!! i need to check AFM, only has any idea of how to check it? anyone has this problem before? thanks.. btw it's r33gtst!!
unsure if this belongs here or in a seperate thread, but possibly could be fuerl pressure problem. have the rough idle and almost stalling on deceleration at lights etc problem also.
as engine starts increasing boost, say past 4psi, the car starts to surge and go all on/off labouring. doesnt stall and doesnt make a difference whether in overdrive or normal drive (auto), apart from that the car runs sweet on cruising, but hit a slight ascent from 110km/h the boost starts to rise to compensate for engine load due to hill and it starts labouring. is this possibly the fuel pump problem not being able to deliver right amount of fuel?
dont believe it to be a air leak at this stage anywhere, but anythings possible,
so anyone with any more ideas apart from the rewiring of the fuel pum or a new fuel filter (which im doing this afternoon), im more than open to advice
thanks
thanks
check your AAC valve and adjust ilde speed, and check your AFM for faulty. test your fuelpump to ensure that it works! :cheers:
  • 4 weeks later...
Well let me tell you about my r33s2 . I bought it through a friend from japan along wtih 7 others that he bought and being the exicitable puppy i was i was keen to see it as soon as it landed beautiful on the outside but underneath car/bonnet filthy as all f*** so he had it degresed and thats when my problems started (I think)
If it rained or i washed the car the hicas would cut out (red light on dash) power steer zero. so i went around the whole elec system and sprayed it with lanosol (didnt undo any plugs as i was told that would makes matters worse) that fixed that problem!
Next was the front parking lights kept blowing (and what little hands u must have to change them f***ers) so trace the elec system for those undid all connectors light rub with emery reconnect, lanosol. Havent blown since Fingers crossed.
Next was the idle lots of reasons but thought WTF i'll get microtech installed should get rid of all bugs, more horses (40-50) but no, idle probs still there after many attempts by 3 different dynos.
And just now i went to 3LIT3 FORS3 or daniel to pick DVD manual for r33-2 and he asked me why i was running two blow off valves. Well ive felt dumb in my days but this was one of those really dumb ones as i thought iwas only running one (after market atmos type) (the other is standard factory on pipe to inlet plenum recirc to front of turbo) so theres my idle problem.
Anybody want a BOV on pipe from intercooler to plenum to swap with stainless pipe to replace this unneccessary and annoying piece of technogy.
But in summing up it seems that all the people here have had problems with
1 dirty parts
2 electrical connections
3 BOVs
So check them all and get someone who really knows what hes looking at to help.
I have the R33 Auto, and it was wanting to stall @ junctions and slowing down. For some reason I checked the auto transmission fluid and it took 2 litres to get it to the right hot level. Now, no stalling and perfect rapid gearchanges. Worth bearing in mind for all the auto owners.
Dave
I have an Rb25 and have read this entire thread. I also have this problem, but I think mine may be a little different, my Idle is 900rpm when at normal operating temp then if I hit the gas and rev it to say 5000 then let it go it will drop to 400-500 then gain back up.
If the A/C is on the car will stall.
Heres the strange bit if im aproaching a set of lights and I put the cluch in and just brake to a halt the car will stall, same if I flick it into neutral and roll to a halt.
But if I leave it in gear till the last second before I stop then put the car in neutral or just the clutch in the revs will happily jump back to the 900rpm mark.
I recently replaced the ECU with a wolf3d and it works a charm for everything but the idle. Im sure its not the ECU because I had this problem with the stock r33 ecu aswell the only difference is it seems to stall quicker withthe wolf and I have less time to catch the revs and stop.
Why is it only if the car idles while moving do I have a problem? can anyone think of anything that can narrow it down??
Cheers
Dave
I'm amazed there are so many people with the same problem. I thought I was the only one!?
Tried just about everything... the only thing that remotely helped the idle problem was blocking off the return line - not a long term fix obviously - 100+ psi is not good for injectors.
I will try tomorrow - got nothing to loose I spose... willing to try anything at this stage.
  • 3 weeks later...
i have had this same problem, especially at the lights when the clutch is in...
i found my problem to be faulty/dodgey wiring to the AFM... i can just touch the wires that clip into it and the car will stall...
hope this helps :P
hey guys i think wat said about the battery thing works, coz mine started to stall only when i installed my system, coz i unplugged the batt.. i tried wat he said and the stalling stopped.....
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
