just replying to cam r u running an aftermarket bov and an air flow meter or a map sensor i know that some nissans run a system that when engine rpm is below 2000rpm the fuel pump circuit switches voltage from 12v back to 9vdue to fuel pumps being too noisey toyota soarers run this system as well have u set base idle and iac learnt where base idle is car looks great
  • Replies 242
maybe some help with nissans stalling are most of the cars have standard ecu and aftermarket bovs because when bovs fitted the bov stays open @ idle because of the manifold vaccum which in turn bypasses the airflowmeter and run exceessivly lean so when u up the fuel preassure may temp fix the problem to check to see if problem fixed put a 1 way chek valve on the vaccum side of bov e.g xf falcons have a 1 way valve on the carby version its green and black this stops the bov openning @ idle or when pulling up to lights and still when on boost holds the bov shut and when gears changed only lets of excess preassure and not too much boost which in return slows turbo lag. just trying to help a few nissan owners
cheers.
I just recently purchased a 1995 Series II R33 and it appears to have a stalling problem aswell.
The spedo first started to just drop out down to 0 and would come back if i gave it a bit of a tap. it still does it now. I had a 3point alarm system installed, and not long after getting it back the car began to stall. it doesnt just stall at a low rpm but usually does around 400rpm. I could be driving and the power will just cut out. not just when i am approaching a stop point.
Im not sure if it could be something that happened when they installed the alarm system or if it could be something relating to the spedo and the wiring in the dash with its gauges, just looking at some of the other posts it makes me think it could be something else.
any suggestions would be greatly appreciated.
I would like to share my own stalling experience.
I have a r32 gtst auto (full 3inch system is the only mod), my car use to stall when coming to a stop, going around corners, and at times when cruising at around 3 grand bunny hop. Occasionally it would cut out even when i wasn't coming to a stop.
The solution to my problem was really quite simple. Clean the airflow meter.
So i took off the airflow meter and gave the sensor a good clean with electrical contact cleaner (available at Tandy dick smith etc). Now, no more stalling issues.
I can tell you the most important thing all the nissan people out there, the connector/s to airflow meter is the most crital connection in the entire engine managment and it is the cause of most problems in nissans of any breed. After all the MAF is used in practically all fuel based mathematical calculations within the ecu. If you have any problems with you car running shit go and check the connetor to the MAF. I guaranty it will fix most problems
hey guys. i have a r32 GTR and i started to stall the other night =( the revs kept dropping and it wanted to stall it was ok for abit i took it for a spin around the block and it stalled on me i took it back home and left it running for awhile and it kept stalling and stalling and stalling. so i turned it back on and hit the throttle afew times to about 4000rpm then let go i got alot of black smoke coming and it back fired like a mother =(. think this could be just a fuel pump prob? black smoke? back fire? anyway could someone give me more detail instructions as to how to ground this earth fire on the fuel pump? like a picture diagram ^_^ thanx
Sounds like it is running extremely rich, for what reason I dont know though.
  • 3 weeks later...
I think everyone should check out there CRANK ANGLE SENSOR - Coil Packs - & for series one rb25det's , they should check out the signals coming out of the Ignitor pack, that sits above coil pack #6
like anyone is going to listen to you in this community mate u screw people
f#ck off
mmm my 33 does it, infact did it twice today.... only mods i got are pod and bleed valve...... scared the shit out of me coz i was coming to an intersection and i slowed to take the corner, car stalled but i didnt realise for some f**ked up reason lol coz i still had lots of momentum, but i lost power steering while i was half way through the corner and allmost hit a car coming the other way :s
threw it back into second and took foot off the clutch and it roll started and was all good again, but it scared the $hit out of me
-Ruffels
Might be a TPS error if the MAF sensor has been checked and believed to be working. Calibrate the TPS so that it is 0% with the throttle shut. Take note you will probly need a Nissan Consult to perform this proceedure. This should kick in the IAC valve when the throttle is shut, ie when coming to a stop. Let us know how you go.
mine was starting to do that quite a bit.. going from higher speeds to low speed turns, revs would dip, then jump up. Sometimes they wouldn't jump up enoigh and it would stall. Changed AFM over the weekend.. problem fixed. The other one was dirty I'd imagine.
  • 3 weeks later...
it is weird how all nissan owners come across this somehow
got the problem in my 180 at the moment - car is in shop and let mech know so hoping he can find it
the usual checklist to go over is as follows:
* check all your vacuum lines for leaks
* check bov isnt leaking
* check AFM
* check o2 sensor
* check TPS
* check IACV
* check fuel pressure (which is wat this re-grounding the fuel pump earth whoo haa is...)
* check ecu pin outs and connections
* check not running excessively lean or rich
that seems to be all the usual suspects and if you check all of them thoroughly you SHOULD fine the problem
  • 1 month later...
could somebody please tell me which wire needs to be cut and re earthed. i cut the black wire that comes from the pump and re earthed it. it didnt do much, but my fuel gauge reads empty. so im guessing thats not the right wire. how can i find out witch wire is meant for grounding??
I have an R32. I believe that the ground is the top-right wire when looking at the pump-side clip. It is a white wire which is thicker than the others. I think the others are as in this diagram
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
