  • Replies 242
Guest Sim32
hey i just got my car, for a week it was fine, ran great.
but now the thing seem to do exactly what u guys have been describing. like stalling when u slow down at a lights..well not stalling just dipping real low, 100 + rpm then then just before cutting out the engine seems to regather itsself and go up again. But it fluctuates heaps, and just doesnt sit on a nice idle speed like it did. The car has stalled on me about 3 times..
starting to annoy me..
What is this ACC valve u speak of? and where is it? and how can u clean it??
also, do u have any pics of earthing the fuel pump?
cheers.
Sim32,
For RB20-25 motor
The AAC valve (Auxilliary Air Control Valve) is located at the back of the plenum chamber (inlet manifold) there is a maroon electrical plug (brittle) and a hose which need to be removed first then there is four ten millimeter bolts that also need to be removed before the whole assembly can be (careful if you want to use the orignal gasket again) removed from the car.
then there is two screws that hold the solenoid on, once this is removed the remaining assembly can be cleaned by useing carby cleaner (I used kero and a compressor to dry and clear any blockages) also make sure that the spring moves(smooth) and the valve works.
Reassemble in reverse order with a bit of sensor safe silicon with the original gasket(or you could make another one it depends on weather the gasket comes off in one piece) hope this helps!
It really is quite easy!
Stuttering might be spark plugs, have them gaped to 0.8mm this helps (platinum/iridium plugs also are a good choice for turbocharged engines)
MEGA
hmm thats not the way I understand it works on an RB20.....
The ECU just looks to switch the power to the fuel pump via the relay so that:
*When the ignition is turned on, the pump is powered for 5 sec
*When the engine is cranking/running the pump is powered
I think that the ecu uses a signal from the AFM to determine when the engine is cranking/running. This means that in the event of an accident where the engine stops, the ecu will turn the fuel pump off - a safety feature.
The fuel pump control modulator also acts like a relay to control the voltage (and hence current) across the fuel pump by switching a resistor in and out. The resistor is located between the pump and earth and the switching is controlled by a signal from the ECU.
So if you earth the pump straight to the chassis it will always receive full voltage and therefore run at full capacity whenever the ecu wants the it to run. (You might as well also remove the control modulator and resistor because this effectively short circuits their operation)
If you short the relay then the modulator should still control the pump in the same way as before but you have just removed the functionality of the fuel cut safety feature.
I have any of this wrong someone please correct me.
Im having similar problems with my rb20det silvia. A mechanic friend adjusted an idle thing on the back of the manifold. It has improved but occasionally the idle drops and raises dramatically and when changing down gears sometimes it stalls. I have new iridium plugs, new vl turbo fuel pump. Do you think that maybe i need a regulator at all? This is really bugging me.
well after doing what brownie has told me is *wrong* i have not had a problem at all and im the envy of my mates with 32/33's as all have bad idles.
Thats only the way I understand the system operates.
If you want me to, I can post up a schematic of the fuel system and you can explain how it works.
Guest VuDuDoc
Originally posted by Nizmo32_Josh
no left the earth on the fuel pump alone and bypassed a relay
can you explain which spades are by passed? i look at the top and see the numbering on the relay but what is by passed?
and could it be that the pump is stuck in somewhat of an idle where pump output doesnt vary with accelertation/deceleration?
  • 1 month later...
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
