Guys,
THROTTLE BODY.
Get your cooler piping off it, spray carby cleaner all over and behind the butterfly valve and let is soak. Wipe out as much as you can then start the car up and go for a drive.
So much detritus accumulates there over a cars life and it can really affect performance AND IDLING.
My idle has stabilized and i no longer stall on trailing throttle after cleaning out the TB.
Blacky.
Edited by blacky
  • 4 weeks later...
  • Replies 242
could somebody please tell me which wire needs to be cut and re earthed. i cut the black wire that comes from the pump and re earthed it. it didnt do much, but my fuel gauge reads empty. so im guessing thats not the right wire. how can i find out witch wire is meant for grounding??
could somebody let me know.
Installed my sequential BOV and got the same problem, don't really wanna pull wires or anything, anyone oknow any shops that can retune it at a good price?
the only thing thats bugging me is the wear on the spark plugs, i can live with the stall but just not the thought that my plugs are getting f**ked over
  • 1 month later...
Replacing the TPS fixed the low idle problem for me perfectly. No more looking like a nooby who can't drive manual or stalling it in crawling traffic! My engine is stock tho, nfi for ppl with mods.
I got the same stalling issue with my 180sx sr20det
it is not the blow of valve as i have GFB Stealth and i plumbed it back 100% still does the same thing.
the car doesent stall but rpm drop to around 200 and back up.
can somebody please tell me if i need to actualy cut the negative wire or do i just strip the wire and weld a new 1 to it and make more negative power from it?
thanks
  • 3 months later...
I have similar problems to everyone else here, the difference I suppose with mine is that it comes and goes (Ie one week its evident then the car might drive absolutely perfectly for around a month then revert back etc.)
When its bad these are the symptoms:
1)Eratic idle on cold start and warm start, revs between 500rpm-1100 or so.
2)When driving slowly in first or second, the car actually starts to surge like there is a problem with the driveline (there isn't it only happens when the suring is happening).
3) The car seems to stumble, what I mean by this is that if you were to rev the car in neutral it will take a bit longer than normal to drop properly, but when it does you can feel the whole car vibrate from the engine 'stumbling', when the car is working fine, you rev it in neutral and it drops back down straight away and without any hesitation.
4) I notice alot more popping/gurgling from the exhaust when downshifting through gears usually between 3000rpm and lower, car normally just sounds smooth.
I was just wondering if anyone else has any of these problems as well?
-Tom
I have the exact same symptons you are describing with my U13 SR20DET in my Pulsar. It's on and off at times but most off than on. It pops a hell lot when cruising off throttle. Boost is very laggy and when driving slow it likes to jerk on and off. It also feels very sensitive and rough to drive.
I have a feeling my idle air control valve is stuffed and my timing is out or there's a leak.
Edited by Scandrew
my stalling issue was ECU related.. just an idea to try a swap with someone after trying all these different tests.. (im not reading 6 pages to see if this has been suggested :P )
went from std ECU to power FC and fixed straight away ..
Nice read even thou it took me bloody hours to read but worth seeing peoples problems..
I myself have the same problem?
First: turn car on ( cold ) it idles and car tends to shake like miss fire
second: i take my AFM out but instead of taking it bits i just sprayed it from the outside? but had it checked with the diagnostic and it came out AFM? unless my afm has had it!!
3rd: changed spark plugs, replaced it with second hand coils ( they looked fine ) new fuel filter!! same problem...
4th: cleaned my AAC.. same problem.. installed blow off valve.. same problem..
so my question is? if AFM is faulty ( error ) when tested. can that cause the car to miss fire and idle ( causing the car to behave and have a fit?
  • 6 months later...
Hello everyone, well after reading through the dozen pages so far, I think I've determined my issue to be the fuel pump from what people have said.
I have an R33 GTS-T S2 with a 3 inch system being the only engine mod. Before coming to this conclusion I have fixed all air leaks on intake & exhaust, cleaned my afm, changed my boost control back to stock, cleaned the AAC valve & redone my base idle. I have the idle set to about 850-900 rpm at the moment so to help combat the problem. The idle itself is nice & smooth with no variation, something that was a problem before fixing the air leaks.
My main issue is now is that if I try to just ride the clutch or take off without at least 1500 rpm on the dial the car stalls very easy. Once moving I goes just as fast & hard as it should. Also if I rev the car while stationary it sometimes drops to as low as 400 rpm after lifting off, before coming back up to normal idle.
This leads me to believe that the Dropping resistor NOT the Fuel pump control module is the main issue as this resistor is what the pump earths through at idle. Once you are on the move then the Fuel Pump Control Module (FPCM) then takes over by giving the pump a stronger earth feed.
What I want to know though, as it hasn't been mentioned anywhere including here that I have looked, is where the hell are the FPCM & Dropping resistor located? Personally I'd rather maintain the the proper pump control setup rather than just chop the pump earth & ground it directly. This solution is perfectly fine, but I'm a fussy bugger & want to to the job properly. If anyone can tell me I'll post up a proper mod once I've found a deacent solution.
Cheers
Well I had a Dyno run last weekend & thought it was time to change a couple of parts. So I did the fuel filter & the O2 sensor, since this was a couple of parts that were due to be changed.
Now to my surprise, my problem is 90% fixed, with minimal issues now with stalling on takeoff. I can now ride the clutch on a hill with & even take off with no throttle if I ease the clutch out slowly. It still wants to bog down just a tad if I release the clutch a bit quick, but it is sooo much better :P . The main reason I'm surprised is that when I tried disconnecting the O2 sensor the way the engine operated didn't change. This probably in hindsight meant the sensor was completely dead however.
I don't know if the fuel pump fix will have any influence now, but I'm still going to try it once I find the controller etc. Will post up what happens.
Well your fuel consumption wouldn't be too flash I'm betting. Mine was up to something around 15L/100km, used to be more like 13. Haven't gone though a full tank yet so will be interested to see how much it has improved next week when I fill up again.
The O2 sensor should help rather than hinder your tune. Sounds like it must be buggered. Spend the money & get a replacement, worth every cent.
Edited by JazzaR33
  • 6 months later...
  • 2 months later...
Rofl, wtf, check the service manual, use a multimeter, faaaark this threads ancient
Assuming the body of the sensor is earthed, check it with each pin on the plug with a MM ^^
Edited by GeeTR
I had the same stalling dramas after I got my PFC tuned. Only way the tuner could fix it was by moving the AFM further away from the turbo. I have a GT30 and the amount of air that was going back and forth from flutter was freaking out my AFM. Hasn't idly hunted or stalled for ages at the lights.
  • 10 months later...
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
