hi all im new here
im interested in getting a stagea by the end of the yr dont no a heap about them only no a lil from wiki and some reading though some of the posts on here, i do like the idea of a wagon with a lil bit of go would like to hear from ppl that own one what is the best stagea model/yr in regards to modification ability, stock speed and perfomance
i def want a awd and turbo, does that narrow it down a bit.
also after looking into them a bit iv seen that alot of the stuff that fits onto a skyline will fit a stag is this true is it pritty much same mods can be made to a stag thats done to a skyline.
https://www.sau.com.au/forums/topic/408005-whats-better/
  • Replies 56
Most Stageas brought into Australia will be awd and turbo. Read the section above on buying a C34. If modifying is your thing C34s are easier to modify than the later V6 versions but anything is possible if you have the budget and will.
Series 1 C34 Stageas have the R33 motor and have the problem in auto version that the ecu contains the auto ecu and is not easy to upgrade (going manual solves this).
Series 2 C34 have the Neo engine and can be Nistuned.
If the budget allows start with a 260RS (RB26DETT, manual box, brembos etc)
Unless you are dead set on doing all the work yourself you could save money by buying a modfied Stagea from this forum - there are usually a few for sale at any time.
Good luck!
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6506495
My suggestion is to drive them both, I think you will find the NM35 will be the better buy now you can pick them up as cheap as the older C34 models. PM35 is still a little pricey but you get the 3.5L VQ35.
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6506550
206kw
Volvos
Camrys
Heaps
Stickers NISMO!
But seriously, have a look on carsales mate, you will soon figure out what you like, what you don't like. Please use the search function to look up common questions- its not the first time someone has tried to get more power outta a RB25DET. If your stuck on Manual then your only option is C34. If you don't mind auto, then M35 is also available
http://www.carsales....ice:Min,Max~0.5
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6506774
I have a fantastic NM35 Axis Autech for sale that I am sure you will love.....
http://www.carsales.com.au/private/details/nissan-stagea-2002-13142658?base=1216&vertical=Car&cr=0&eapi=2&__N=1246+1247+1252+1282+1216&find=yge062|CarAll&silo=Stock&num=15&sort=default
You should also find a thread on page 2 of the Stagea Forums discussions....
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6506872
C34 has a lot more off the shelf parts if you are looking to mod.
M35 is the quicker car in stock form for sure (I was originally looking at buying a C34 prior to buying my old NM35) unless you are looking at the 260RS.
If you want manual, only choice is C34.
M35 is much more refined and comfortable as you'd expect from a newer model.
Looks are subjective.
Perhaps you need to go to a few dealerships and take a few examples of each model for a spin?
Edited by iamhe77
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6508324
so stock both of them are as fast as each other ?? is the m35 the only one with a split boot opening? anyone own 1 or both of them what are the good and bad points of both models c34 and m35
If you want to modify one then it hardly matters how they go in stock form. They are both heavy and are compromised by that fact.
If you want a manual then it is an easy decision. If you want to modify the car, C34's are easier to source parts most particularly engine management and are generally easier to work on.
If you value more creature comforts and are happy with a slushbox then the M35's are going to look more attractive.
Both are good but they are different enough that all C34 owners are like saints and all M35 owners are devil spawn. :devil:
https://www.sau.com.au/forums/topic/408005-whats-better/#findComment-6508405
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
