  • Replies 56
Yeah Bob & wolverine, I imagine the RB30 should provide the torque the stag needs; will post dyno sheets & all, but im yet to drive it or start it for that matter! Still got some work to do, like manual conversion & rear manual subframe from GTR, plus finish brake conversion & then tune! But, im expecting over 350awkw & a truck load of torque, so im sure that will get it off its fat arse!
My s1 has elec mirrors, I assumed they all did?! As for what to look out for, well like any car, things age & wear. If its had an easy life & kept well maintained, it should run happy for years. But things occasionally do go wrong & such is cars! If its done over 100k then check if it had its major service & timing belt done. No turbo noise. Good compression. Good cooling system. etc... Service history? Then should be ok!?
Rust under the mirrors is common. Broken or missing door weather strips (expensive & somewhat difficult to get). The mechanicals are very much the same as the R33 GTR & motor is R33 GTST (s1) or R34 GTT (s2) or R33 GTR (260RS)! Read all the threads, it will give you a pretty good idea of whats going on with Stageas & what people want or have problems with, lots of info in the stickies too!
These cars are pretty tough to a point, so if left std & driven normally, then you shouldnt have any real issues! If you chose to mod &/or drive "spirited", then you have "swallowed the red pill" (time to get your hands dirty & your wallet cleaned)!
Buy one, they're awesome!
Is the only reason not to pick an 260 due to the price what are the engines like and performance upgrades are they easy as on the other motors like say if they were they same price to buy and u put the same money or mods on which would end up a better car performance and drivability and life of the car
The Autech 260RS is the better car, though very similar to the RS4S in most areas. The 260RS is an R33 GTR mechanically! The RS4S uses the R34 GTT engine & has standard s2 Stagea brakes (smaller than the 260RS Brembos), different body kit, along with a few other minor changes! But the RS4S is roughly half the price over here! So with the money saved, you could make the RS4S better for less, if you want to mod it! But if money is no issue or you dont want to mess with it too much, then the 260RS is the best Stagea in the range (besides the elusive Nismo Stagea, which is mechanically the same as the Autech 260RS anyway)!
Performance = 260RS
Value = RS4S
If your going nuts on building a monster, then might as well use a S1!
Basically, If I won Lotto or something I would hunt down & buy the Nismo 260RS, just to have it on the compliance plate, but seeing as I have a S1 RS4V already, I would just finish building that, as it wouldnt matter which car I started with, they'd both end up the same!
They all have a very similar drivability, all offer similar performance once modified, life of the car is the same!
Just work out your budget or other confining factors, what you want/need to do with the car; then decide on which best suits your needs & wants! (There isnt a bad Stagea, they are all awesome, thats why we own them!)
Zorro has the right of it.
If you are budget conscious then it's hard to go past an S2 RS4S (or S1 for that matter). It's 85% of the 260rs for half the price. To make it 120% of the RS will still cost less than an RS. But then, at the end of the day, it's not an RS.
If you specifically want an RS because it's an RS then go for it, I doubt you'll be disappointed. Just bear in mind there is a cheaper way to get into a stag or cheaper a way to get into a faster stag by starting with an RS4S.
Auto's only
1 for snow (2 gear takeoff i think, maybe also 50/50 torque split)
power is auto too (earlier kickdown)
auto's also have the awd button (locks 50/50 up to like 40kmh or something like that)
Manuals get none of this
Are there any problems with any models as you put the kms on these cars want to what the life of them are like
The stageas are built well mate. Mines just passing 210,000kms with nothing but regular servicing. Including alot of hard driving and even a few track days. Except for a clutch which is the result of abuse with the front shaft out :D
Do they have a speed limiter at 180km is it possible to override or remove this
Do the rs4s all have the neo engine ?
I honestly believe ALL your questions and queries will be answered by inspecting a few C34's and M35's, test driving both.
Otherwise this thread will drag on forever without a final conclusion and you'll still be none the wiser.
Do they have a speed limiter at 180km is it possible to override or remove this Do the rs4s all have the neo engine ?
yes and yes
all s2 c34's have neo's
and the manuals only came out as s2's (apart from the 260rs's)
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
