Some people still fit an adjustable cam gear to the factory exhaust cam.
My RB26 had just an adjustable cam gear on the factory exhaust cam from Japan.
I'll be fitting one on the exhaust cam of my NEO. I'm using factory cams for the time being with the notion of changing to after market cams down the track. I'll get my tuner to play around with the exhaust cam timing. If it so happens to be an advantage then awesome. If not then it will come in handy later on.
My NEO has the exhaust cam gear and poncams, was adjusted slightly i think!
Certainly shouldn't be on the top of your list - especially not with a stock motor - and nor should cams be near the top.
When you have done the full exhaust, fullflow air filter, fmic, bigger injectors, Z32afm, new fuel pump, better turbo, upgraded ecu you may find that with an adjustable exhaust gear only you can shift some of your top end power to the midrange.
When I had the RB25DET on about 250awkw I had mine dynoed and best result was about 3.5 deg ret from memory and it gained about 8 kw at about 3500 -4000 and a few off the top. And no didn't loctite the set screws - someone posted that they were the weak point on cheap cam gears so I went to the engineering supplies and they said they were already good quality high tensile (had the standard stamped on them) so I just did them up tight with the hex key and they never moved. No reason not to loctite I suppose once you're happy with the tune.
Hi guys,
I'm looking to get my car tunned on e85 in coming weeks and was thinking about putting adj. cam gear on ex side. Its for built 25 with tomei 256/8.5 poncams, 35R .86 etc. It's been making 470-480 whp @1.6 bar for few years and makes full boost by 4500rpm
How much gain can I expect from playing with cam gear if any?
Cheers
G.
Edited by 3BEPKA
  • 11 months later...
Any definative answer on a Exhaust cam gear for a RB25 NEO? I've got the 100k service coming up and want to know if its worth popping one on.
Still stock turbo, but will upgrade later on down the track. If its only a few KW I don't think I'll bother
In this case, dont bother :)
Is it worth popping one on though for later on down the track with a bigger turbo/injectors?
I've read pages of old threads today and everyone has a differant opinion, most of which seems to suggest the standard NEO cams do a pretty good job without adjustment.
What gains or lack of did you guys experience?
I run poncams so the the adjustable gear sits at 0 and does bugger all.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
