Hey guys, I'm having issue with my 34 still. I found out the vct solenoid is no longer working and leaking through the plug. Need to know if anyone can confirm a hot start problem with the vct not plugged in. I'm trying to source a solenoid but its proving difficult. fuel consumption is poo, car is hard to start once its warm, and has shocking performance.
Does anyone know if a failed vct would give a hot start prob.
https://www.sau.com.au/forums/topic/408053-r34-gt-vct-solenoid/
No
VCT doesnt turn on at idle, and AFAIK your startup would not trigger it either.
It's hard to say if the poor performance has anything to do with the solenoid or if you have another problem that is causing all your issues
I don't believe it would screw up your fuel economy. I'm not sure if vct is active at cruise off the top of my head but don't think it would hurt your economy to much if it was on
Someone smarter then me might know more. But off the top of my head i don't think so
I thought vct advanced the timing through certain rev ranges to let more air into the cylinders? Not sure on this but i think i read somewhere it did. So if its not working then it would burn more fuel wouldnt it?
Advanced Timing doesn't "let more air in" it changes the point in the cycle when the spark plugs fire to burn fuel
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
