I have searched, perhaps my skills in doing so aren't quite up to scratch but have done so regardless.
http://www.skylinesaustralia.com/forums/topic/218752-nismo-fuel-pump-for-32-gtr/
So I plan on using a Nismo pump in a 33 gtr, to my understanding, they flow 276L/h @ 12.5V
Stock wiring to fuel pump generally does not see 12.5V does it?
Therefore I'd like to know if it is just as important to rewire for the Nismo as there was no answer to
a similar question in the above thread.
Regards
Michael
https://www.sau.com.au/forums/topic/408068-nismo-fuel-pump-rewire/
Absolutely. Run a new wire from the battery and a relay. Make sure the wire is 6mm and just trigger the relay from the stock power feed.
Thanks for clarifying, so it can be done exactly like so on an R33 GTR right?:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=289665
It's a little bit confusing because the below diagram seems to teach a slightly different method (or is it the same?):
http://hosting06.imagecross.com/image-hosting-07/7591FUEL.jpg
Is there one method which betters the other?
The former (NARVA relay) seems easier.
When i rewired the fuel pump in my 33 GTR (nismo unit) i rewired the WHOLE thing. I got rid of the fuel pump speed controller, ran new earth and new feed and relay with a fuse in line, cost me about 50 bux in parts(heatshrink, solder, relay, inline fuse holder, some QUALITY terminals)
No I mean the diagram just looks like a standard 5 pin relay setup. Nothing special.
Or was the purpose of the diagram to explain how a relay is wired?
Oh yeah just to put it in a drawing. I found the DIY a biit confusing (where its just written) so thought I'd do a diagram that shows how to do it with the R33 wiring. Its a basic circuit but might help the OP. Only problem I had figuring it out was working out the positive feed because I didnt have anything to test it so just made up a test light. And yes forgot to add the fuse in. I have a 20amp fuse between battery and relay Edited by 89CAL
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
