Hello everyone. I got a 1990 gtst type m that i have had for the past 6 years (import law in canada is 15 yrs). Just slipped a bearing in my rb20 but i love the car and am going to keep it for a long time. That is what brings me here... Rb 30 bottom end. I figure if im going to keep it might as well do it right. :) so Just wondering if anybody has a bottom end kicking around. I am considering a 25/30 build and have a few questions... Has anybody shipped these overseas? Whats the total weight? Approximate cost to ship wouldnt be cheap but it does seem worth it... Let me know what you guys think. Also sorry for not introducing myself the link wouldnt work off my phone....
Thanks a bunch guys
James
https://www.sau.com.au/forums/topic/408075-rb30-shipped-to-can/
just be a bit careful bringing over a bare block from here....there were 000s sold but they tend to be in bad condition by now.....plenty of people have checked more than 1 block before finding one that looks OK.
I'd be buying from RIPS for the certainty
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
