Woo Hoo Dump Pipe Finially Arrived
  • Replies 152
Originally posted by Black33
muffler man in prahran - he's meant to know his stuff but really annoyed me last night.
ok if he made a comment about it - but I had to hear him go on about it for about 15 mins???!!!
so, did you feel an improvement from the dump only??
dont tell me any of the dribble he told u, u actually believe?
The parahn guy is prob a V8 guy.
As i said before it definately helps spool quicker and come on to boost alot earlier, like it from proven from my dyno graph!
U should tell the exhaust guy to give HKS a call and winge to them about how they have wasted millions of dollars flow testing dump pipes with seperated pipes for wastegate and exhaust gases! :lol:
yeah I know, that's my opinion too :(
But do you know how big the outlets (at the turbo flange side) are on one of the hks dump pipes??
Our dump is like 2 1/4" and the wastegate pipe is 1 1/4"
heres a pic of the dump pipes jms sell!
look familiar?
dont worry what that v8 yobbo exhaust guy in parahn says, he would not know shit!
hey inasnt,
I am trying to get in touch with the guys at ICE to see if they can get their exhaust guys to fit my dump and make up a front pipe and flare out my cat inlet/outlet - did you use them?
Are they any good?
yep ice fitted the dump, exhaust place near there modified my front pipe to fit!
Geralds mobile number is 0414359888.
interesting thread lads...
just a few questions ....
1. could someone please post a picture of the OEM dump pipe?
2. will an R33 dump pipe fit an R34 GTT?
3. what a/f ratio does the standard skyline run at?
4. i've looked up this place "arrows diff" in the whitepages but i can't find a listing? does anyone have a contact phone number?
5. INAST - you had problems with the dump not fitting from arrow's correctly? have arrows since fixed this? BLACK33 perhaps would know seeing as though he bought 1 after INAST?
why the hell are these forums split up into state...!!! this is soo annoying.... :)
franks
1. I have posed and so has black33 pics of the dump pipes in this thread.
2. The oulet flange for the r32 and r33 turbos are the same, dont know about the r34 tho. If the r34 has the same turbo as the r33 then yes it will fit.
3. my stock a/f were runnin near 10.0, which is rich as a bitch!
4. as black33 said!
5. the outlet of the dump pipe to front pipe is angles differently to the stock dump so i had to get my front pipe cut and rotated to join the new dump, no dramas with that part anyway!
6. what r u doin sneeking around the vic section??!! hehe kidding!! :)
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
