Woo Hoo Dump Pipe Finially Arrived
  Quote
Originally posted by Black33
meggala,
when I tried to turn my boost down all the way (I turned the bleed valve until it was shut), I went for a drive and the car was terrible, as if if had no power at all, boost was really low (shouldn't it just go to 0.5bar?)
dunno what to do?
It still runs ok (quicker than standard) on 10psi, but my point is that it lost some power when I put the dump on. I might as well put my standard cast dump pipe on for a power increase? :(
But seriously,  if I get it on a dyno and it shows that it has timing and fuel probs, is there anything that can be done to iron it out before I get an SAFC?
man man man, get your car on the dyno at ice on saturday and get everything checked out!
If u have lost power by putting on your dump then your car must be irish not japanese!
  • Replies 152
meggala,
my dads buying me a new safc from nengun and i want a place to dyno it in melbourne ,And it seems like u have seen a few get done do u work a peformance shop?Where do u recomend ?And this 'ice' place where is it ?Cause im from the western suburbs .Also what settings would i need to get her started and drive her?
  Quote
turned boost back down to normal (got rid of bleed valve) and it runs smooth as, I've come to the conclusion that:
1. before dump I had it at 11psi and it was pretty smooth b/c it wasn't getting too much air so A/F ratios weren't too bad
2. After putting dump in, it's letting so much more air flow through that combined with boost the stock ecu sh*ts itself and give me massive flat spots.
In other words I will wait before I get my SAFC before I put my bleed valve back in.
I need help with one thing though!!!!!
After installing the dump, I've noticed that I get really big spikes, even with the stock boost set up back together. It spikes around 3psi which I was never getting when I didn't have the dump - Can Anyone Help Explain this?
I though it might be the type of dump I got b/c it has 2 seperate pipes and the wastegate pipe is only 1 1/4 inch diameter. Don't know if it flows enough for the wastegate, meaning that the turbo can't bypass all the pressure when at high revs and it spikes.
Is it something else.
Help appreciated.
Thanks guys (sorry 4 such a long one!)
The wastegate pipe aint 2 small, look at franks hks dump, its the same size!
  Quote
Originally posted by meggala
black r33 wind your boost down a bit and see if it help wind it down to 8 psi or so more boost doesn't nessacarliy maen more power then get the s-afc tuned.
franks here in melbourne we have had some very good results with the s-afc tuning 15 20 rwkw iis gain quite often.
exstatic doesn't need to jsut ify the gain cause most of us were there when he got the gains and saw them with our own eyes
meggala
franks?Where need a place asap!Also meggala do u no u have never answerd any of my questions to u ?
  • 1 month later...
  • 1 month later...
Arrgh if only i knew exactly what and where to get for my exhaust
I'm after a Front pipe + Dump pipe
3 of my local exhaust places know jack squat and i've just emailed UAS hoping for a half-decent reply but know it will cost the earth through them.
Benm, i just ordered a dump from JMS (japanese motorsport) in Adelaide and am waiting for it to arrive. They have stainless dump and front pipes for a reasonable price. I'll post some pics when it arrives and can let you know what the quality is like.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
