hey guys i have a s2 rs4s and its knocking/rattling. ive checked it with a stethascope, and the noise is coming from the rear of the engine or bellhousing. i believe these have a dual mass flywheel and this is where the noise is coming from but looking for some clarification from anyone whos pulled a fly wheel out of one.
cheers.
Never seen a dual mass flywheel on an RB but then I haven't seen that many RB flywheels. I would think it very unlikely. On the other hand it is quite possible that someone has fitted a twin plate clutch if your engine has been heavily modified (they are not standard).
Or else you have a screw loose somewhere?!!
this is an oem replacement for a dual mass flywheel on an R34 GT-R
OEM equivalent clutch kit including DMF NSK-7725DMF
this is also for sale on SAU
from an R34 GT-R VSpec
Stock used
Used dual-mass flywheel now for sale - Will inspect condition and update. For now price = $250, may go up or down $50 depending on confirmed condition (will post pics)
so skylines definalty have them and i thought, being a NEO engine, with gtr gearbox(if that waht the awd box is), it may have the GTR dual mass flywheel. im not sure if the GTT had them, but its possible aswell.
Edited by OMY31T
Well I remain unconvinced. From my "research" the only Skyline to have a dual mass flywheel as OEM is the R34GTR with the 6 speed Getrag although aftermarket dmfs are around.
I have an R33GTR box and clutch in my Stagea and the clutch and flywheel came out of a low mileage R33GTR and its a solid flywheel. I'll bet quids that the RS4s came out with a solid flywheel.
mmmm i guess ill just have to pull it out, because its really the only explaination for the noise that i can come up with.... it doesnt sound like piston slap, and all of the cylinder compression are good, i thought it may have been the idler or tensioner pulley for the timing belt, but they have been checked and are fine. the car drives beautifully so its unlikely to be an internal bearing.....
this has really got me by the short and curlys, its all thats stopping me from sending the turbo off to hypergear, got the FMIC, fuel pump, z32afm, hard pipe intake, all i need is the turbo and ecu + tune, but im not going to send it off and power it up if its going to cause more problems...
As stated before, 6 speeds get dual mass flywheels a la 34gtr and s15
Quite likely to have copped a twin plate clutch in japland, extra likely if your clutch is quite firm
Disconnect either injectors or spark down the back end of the motor (one at a time) and check if the noise goes.
If it does it will more than likely be big end bearings, Happened to me on my R33 a few years back.
i think i answered my own question after further googling it seems the Rs4s from 97 onwards has a dual mass flywheel
:D
My RS4S is a 98 and as i have the flywheel out sitting next to the gearbox on the floor, i can tell u its definately NOT a dual mass flywheel. The noise is prob the throw out bearing. Mine was noisy.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
