Hey,
I did a little searching and there's is a thread out there but I need some specific questions answered :)
I own a 2004 300gt and I realized it's lost quite a bit of power, my friends Accord Euro CU2 pulls faster than my 300gt, we tried a little 0-100 test and seem to be getting 8-9 seconds with the aircon and speakers shut off (which should be around 7-7.5).
Are there any specific aftermarket parts that I should be looking at?
At the moment here's what I got in mind for future performance mods:
-Fujitsubo Cat Back
-Motordyne Iso-Thermal Plenum Spacer
-JWT Pop charger w/350z intake
-Unorthodox Racing Pulley Underdrive
-Transgo Shift Kit
-Stillen Grounding Kit
Had a look at the DC Sports headers but I'm not too sure if they would fit onto my VQ30DD
Could my current straight pipe axle back (I think) make me lose power?
Or just the fact that I haven't had a chance to clean my plenum yet?
If someone could shed some light on this for me that would be great.
Thanks,
Richard
Edited by itsRICHARD
https://www.sau.com.au/forums/topic/408154-300gt-performance-upgrades/
Is your engine stock at the moment?
Are you also aware the Fujitsubo is one of the quietest exhausts you can buy?
In regards to the MD spacer, i personally would prefer the Kinetix V+ plenum. You can pick one up for about $300 delivered and it replaces the upper plenum. It is something like 270% more heat resistant than the stock plenum and improves flow to the front 2 cylinders that the OEM plenum restricts. Giving you LESS low end power but MORE high end power. Damian on this forum has just installed his and can also explain to you how he can feel the extra power- i have my Kinetix V+ sitting in my garage but i'm not putting it on yet.
JWT charger with 350z intake is a great idea, it's proven to have more of a power increase than a CAI for the fact that the plastic intake is heat resistant rather than a aluminium intake will gather heat.
Transgo shift kit for an automatic is a great idea I have heard really good things about it, one of my mates with an auto 350gt is about to do his.
Grounding kit again a good idea.
No idea why your losing power, how long have you had the car for? and have you noticed that it is getting slower?
have you considered a full service to spec ? i.e. new spark plugs (when was the last time you changed them if you have changed them) check them for incorrect gaps in the electrode and corrosion or carbon residue
2 - Check your throttle body for build-up gunk and carbon as that can actually become sticky and slow down ur throttle body from opening fast
3 - Check the injectors as these can get filled up with crap from the petrol tank. and it will push less petrol then needed
4 - check oil viscosity and if it looks sludgy an thick then you may need to give it a clean ( getting a qualified mechanic to do this will be expensive but a proper reconditoning will make it like new)
there are a few products that say they can clean the engine before service that you add in the old oil and drive for a few min before service and oil replacement but i would be weary as they can cause engine wear and possibly more bad than good.
4 - When you have your service done do you have the fluids especially oils flushed and replaced or just the common drain and replace. i won’t go into the benefits of a full flush before new oil but its stuff like this that with time will eat up on ur power.
5 - i find that usually the maintenance kept on the car including previous owners can affect the performance more than you think
Also good thing to keep in mind the V series skylines are quite heavy and last time i checked the Accord euro was quite a bit lighter so depending on weight and age of the car the accord may have more power to weight than an older v35 but like i said this depends allot on the maintenance
i have seen a v35 pushing barely 100kw on the dino before service and a healthy 180kw after. and yes the engine inside was full of gunk from oil that was left to long and not flushed propperly. the mechanic had to plug it in a special machine and flush it as high presure with a cleaning product and then new oil , new spark plugs , and new injectors as 2 of the old ones were almost useless.
Yeah my engine is stock at the moment.
Really? I always thought the Fujitsubo was already quite loud, saves me the trouble of attracting too many cops though.
Originally I was looking at the Skunk2 spacer but I did a bit of searching in g35driver and most of them would choose the MotorDyne over the Skunk2, haven't looked at the Kinetix one yet.
I've had the car for about 2 months now, haven't really noticed if it's getting slower. Although this is the fastest car I've driven it definitely does not feel like 130kw-150kw at the wheels stock.
Only things that have been modified on this car is (besides lights etc):
-19x8.5 Rims w/ 245/35/R19 tires
-Straight pipe running from the middle exhaust to the back done at 'Mr Muffler' (that was what I was told by the previous owner)
Compared to other exhausts it's probably the most quiet exhaust, some people like that though, look into the Kinetix V+ plenum its meant to give +15hp i think it is.
Maybe there's no problem at all if you haven't noticed that the car has gotten slower, it could just be the power that it has. My V35 is the fastest car i've owned by a long shot, i hit 60 in town so fast i have to be careful.
@Alex
I was about to bring the car down to RevZone and get it inspected by them. I haven't serviced this car since I bought it yet, next service is due at 79,000kms (Currently at 72,000kms) so I have no clue how's this car been service other than the car been serviced every 10,000kms by Nuwan @ IRev Imports.
I went to speak with Nuwan and he told me not to touch the throttle body because it would cause problems with the car and I would of have to get him to fix it lol
Basically nothings been done since I've purchased this car 2 months ago, the previous owner got the car serviced on the day I purchased the car.
The Accord Euro is actually heavier than the 300GT, I think it was 1.6t? while the 300GT around 1.55t
@Sean
Just feels like there's a lot more power in there somewhere haha
Taa Daa!
Your Correct. It will have no-where near that. Infact, I think it'd be closer to the 100-110kw mark on the dyno that I use. Put it this way- My Stock NA VQ35de put out 130awkw.
Now while you are rwd, you have the middle child version. So I don't think you'll be pulling 150rwkw, not even on the most optimistic of dynos.
Best thing you can do is pull apart and clean all of the intake system right down to the heads, including the TB. Sounds like your Friend Nuwan doesn't know too much about these cars, or else he'd know about the issues they have fouling the intake system. Sort it out, treat it to a new set of plugs and then see how it feels.
If still no good - VQ30DET
do it.
I'll start cleaning the plenum soon, probably over the weekend when I get the chance.
Taa Daa!
do it.
Really? I thought the 350GT were 170awkw stock.
How hard is it to strip down those parts and give them a good clean? Anything I should be careful of? Any recommended plugs?
Still new and learning about cars, so pretty clueless at the moment.
First of all, I'm not very optimistic about power- its just too easy to please the customer by adjusting the dyno to suit. Dynos are comparative tools for your car, and not other peoples cars.
Now, grab a beer/wine/coffee, and sit down and have a long read through this thread- don't be a bish and skip straight to the pictures... wait it out. This is why you clean it up...
http://www.skylinesaustralia.com/forums/topic/277914-any-direct-injected-300gt-250gt-v35s/page__hl__vq30dd
I meant I read that thread just a bit ago lol,
anyways gonna give it a go tomorrow morning and clean the plenum, intake etc.
Don't wanna dig too deep, not too confident in myself
Cleaned the throttle body yesterday and having high rpm issues on start up, roughly 2000 then drops to 800 and bounces up to 1400 and back down to 650, also random rpm spikes when foot is off the accel while driving, going to try the relearn process soon.
Can anybody confirm if the crank pulley in this combo will fit on my VQ30DD?
http://www.conceptzp...7123.243.124.42
Having trouble finding the recommended spark plug for my 300GT 'NGK LFR5AQP'
However the 'LFR5AIX-11' is available on CZP but their not recommended for the 300GT.. but the 250GT and 350GT uses this spark plug..
This is driving me nuts! Too less info on the 300GT :(
Nvm, confirmed with CZP that the pulley should fit, gotta have a look at the headers now
Got a quote for the Fujitsubo full cat back + Fujitsubo Y-Pipe $2000 shipped..
Are there any other alternatives that gives the same/better performance and sound just as good?
Bursons is an NGK distributor...
OP is probably avoiding them because he knows that they will charge some insane price..
Yep, hahaha, but if I have no luck finding it then i guess that's what I have to do
Anyone know which headers I should get for my 300GT?
Spacer, crank pulley, JWT popcharger and z-tube came in today! going to put on the spacer and intake soon. Any clue how much shops will charge me to put on the pulley?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
