Hey guys.
Long time follower, first time forum-join-iner.
I just have a quick question to ask someone that's either done it, or knows if it can be done.
I have an R34 GT-T Sedan. I want to replace the stock gauges in the cluster on the top of the dash with some after-market ones.
I want to know if they can just be placed right in the same mounts and just re-wired or if it's more complicated then that?
Any help would be greatly appreciated. I've put gauges in cars before but I thought I'd ask before I go ripping stock shit apart lol.
Basically the reason for doing so is the volt meter doesn't work and the boost one is a little dodgy. Plus for style as well. Looking at some white face ones like GReddy or something.
Thank you very much :yes:
Hey Alex,
YES, it has been done plenty of times before so you are in luck :) Have seen both the 52mm and the 60mm done successfully. I am looking to put some blue stepper motor gauges in mine in the near future so maybe do a DIY thread on it so its fresh (If you search you will find 2 existing threads on this to give you a hand with it)\
Cheers
Mat
Theres a few ways you can do them really. I found that 60mm Defi guages did not fit and i had to dye grind the surround and wedge the gauges in so they pop out 10mm from the holder (couldnt fit the glass back on) and they looked really good !
Cant comment on other 60mm gauges but i would go with 52mm if you want simplicity.
As for wiring the circuit that powers the tripple gauge holder is actually 1 solid single piece PCB. The only thing you can tap off from the connections there from memory was your power and earth wire (not sure if i ran an external earth all together though) which will get all your gauges to light up and your volt to work. From there you need to run a sensor with a sandwich plate from your oil filter for your oil temp and take it incabin where the gauges are and the same thing for boost with a tee'd off vaccum line.
If your mechanically minded and know how to use a Volt meter its a pretty easy job. If you have little experience then i advise you take it to someone or call a friend to help you out cause there will be alot of head scratching involved lol
Edited by nomnomv8
post-11869-0-26047200-1346425194_thumb.jpgJust done mine with 60mm Defi's, have done them on a previous R34 aswel.
First time i mounted them inside the gauge pod and just modified the original gauge mount inside to hold them in. Looked neat and they were hidden when off, bit of trial and error getting them centered.
This time i wanted them on the outside, so i just removed all the inside's, cut some slots on the round part, then heated it with a heat gun and forced the guage in, so its nice and firmly mounted once it cooled down, doing it this way there is a gap as the pod isnt flat, but i wanted this look this time.
As for the wiring i used the orignal gauge wiring to get 12v+, Ign 12V+ and Illumination 12v+ and then i ran a seperate ground.
Edited by msports180
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
