i just picked up some 'KillerBee' coilovers super cheap, ill report back once they are installed :)
If you're still alive. I am so careful when it comes to important parts, i will always save extra money and buy really good quality things.
What about Nismo? They use Bilstein to manufacture the kits to Nismo's specs
Have you thought about BC's?
http://justjap.com/s...productid=19220
The M35 kit is pretty damn nice and great value for money so I can't see why that wouldn't be the case for the V35 kit
Teins, while nice, are a bit overpriced IMO.
If money is no object, go get some Aragosta or Ohlins.
Edited by iamhe77
I'm having a fantastic day. But my previous comment was just stating that i haven't heard of the brand that you mentioned before. Sorry if it was offensive.
I wrote a massive rant at you. But realistically it's a fair call. The ones I got have reviewed reasonably well. For the price I got them at they are worth a shot.
I would get BC if I was paying full price for them. Good value coilovers
I asked this question earlier today on a V36 facebook forum, general consesus was -
Tein with edfc - freaking wicked really, I would love this set up or KW. If your budget is a bit tighter the BC BR's are the best bang for your buck. Aragosta with roberta cup kit also got a mention.
BC's got a good wrap as being cost effective and good quality.
As for me, poor mans option of Tein s tech springs are probably what I will end up with.
For roughly the same price listed in the link above by iamhe77, i reckon Charles will get them freighted to you with a rear camber kit/toe bolt thrown in - http://g35driver.com...-coilovers.html
Edited by Skylinetragic
Ive got BC BRs in a sedan, got the dampening adjusters at the top which on the rear poke up behind the headrest because of extension thingys saves you taking out your back seats to adjust them. People are truely supprised by the lack of body roll and pitch. Car doesnt squat under hard acceleration.
I did a S**t load of research on the subject a couple of years ago. Found good threads on G35driver
Out of it the opinion is Aragosta, Ohlins, Bilstein, KW, Tein in that order for quality of the above mentioned manufacturers
As for ideal setup & spring rates for Australian roads the Bilstein P9 & 10 were best suited.
I went for the Ohlins as I don't want to be replacing parts or rebuilding them in 12mths and I got a good deal :)
BC's don't get much of a mention
FWIW quoted from G35Driver:
KBee
Coilover: KBee
Style: OEM
Spring Rate: 12K/12K (Swift Springs)
Drop potential: Frame Banger
Adjustability: Height is as easy as any coilover. Dampening for the front is easy, The rear needs to be off the car.
Stiffness: Ridiculous on full still. Pretty comfortable on full soft.
Harshness: You can feel the road beneath you, but you don't hate it.
Price point: These are extremely rare JDM coilovers. They are only available in Japan. @$1200 US
Edited by mosoto
BC BR Series Coil overs, big review on my350z, i have them and track the car + hills and they are great.
Unless you race or have massive money in other suspension parts why pay more? You can then use what you save for sway bars, end links, front and rear sub chassis bracing etc..
i have bilstein coilovers with hyperco springs,i'd say theyre a good compromise for street,winding road,theyre well dampened and the ride is very good but still firm and responsive on turn in.although personally i'd go for something a bit firmer for regular track work.
previously had Zeal Function Xs on another car and was VERY happy with them,excellent for circuit driving but still pretty nice on the road,well dampened,no crashing ride.Not sure if zeal have a kit for V35 or if you have to adapt the z33 kit?
from previous research i recall good opinions on Ohlins and Aragosta also-i think RHDjapan have aragosta kits at a reasonable price :)
Anyone have any idea about the Megan Racing Coilovers?
http://www.conceptzperformance.com/Cart/description.php?II=5035&Car_Type=G35&UID=20120903014237180.189.146.222
Been searching around g35driver and cant seem to find a good review of them..
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
