Lol, was under my car yesterday inspecting clutch fork and noticed I had some pretty fat front pipes already installed. Measured them up to be 2.5 inch primaries into 3 inch secondary. Can't find a brand name on them but the welds look immaculate and it seems quite sturdy. Win! Its funny how sometimes you can own a car for a while and not realize what's done to it.
I'd still be getting bigger pipes mate, what dumps do you run?
I'd be getting 3 inch dumps, the biggest f@ck off front pipes you can find. High flow cat into 3 1/2...
The closer you are to the turbos the larger the diameter of the piping required, as we all know hot air expands ;)
Edited by GTR_JOEY
Conflicting advice everywhere, people say 3inch is good for up to 400kw. Others say 300kw, I love the Internet. I may just sell of my entire system and get a 3.5 inch system made up just to be safe.
With any question there's going to be conflicting info from those that have heard stuff off mates or just take a guess.
I've done it on my own 32. Over 400rwkw through those size front pipes and an off the shelf xforce cat back which I can tell you now is less than 3.5".
Save your money and spend it somewhere else on the car, those front pipes you're talking about will do the job. Plus if they're Nismo the quality will be awesome like all Nismo parts.
Personally I'd be buying those front pipes wherever youve seen them and then a set of R34GTR (or HKS which come up from time to time) dump pipes with the money saved from not going custom/overkill.
^^this man knows,
If stevo reckons that those pipes are good for the power your making then that's good enough for me. Unlike alot of people his advice comes from experience and knowledge.
The nismo pipes will be top quality and you know they are going to bolt in and fit 100% of the time!
Like I said before you will need the bigger dump pipes as well with the high flow cat
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
