R32 Rb25 Powered Gtx35R Build
The owner worked out his keyboard works and posted something for himself :P
Short video of 25psi, Because the car is low and stiff suspension setup for drifting getting a full power run without wheel slip is pretty hard but you get the idea
  • 4 weeks later...
  • 3 weeks later...
On the road it would be around the 4600-4800 its seen full 25psi. Once the boost controller is replaced i would say it will be down around 4300-4600 area. Febuary next year is roughly the month that the car will be swapped over to Ethanol and then should get interesting
  • 2 months later...
Nothing worth reporting on, waiting on the new model boost controller to come out.....dont know which one though, some jap thing with a fancy screen.
Owner has just been driving it and trashing it when he can. Engine holding up well, Only starts to get any blowby oil when its due for a service which is good.
Owner currently overseas so car is just sitting for the moment.........i do know where the keys to it are hmmmmmm
  • 2 months later...
Weird that someone posted on this the exact day it was being worked on.
No boost controller yet BUT!!!!
Not sure of exact date but it wouldnt of been 3 weeks after the last post i made that i get a phone call from the owner saying its broke again..... :angry: sigh.
While being driven around town one of the belts started to squeak a bit, so owner decided he would go to the closest "closed" road and give it a squirt to just clear out the gunk......what followed was a complete dumping of bodily fluids in a trail behind the car. Something in the cooling system failed. The belt squeak must of been coolant starting to leak out onto them.
Towed car home checked it next day to find as much water as could put in it was running out just as fast from the water pump/head area.
At that point the owner said fk it im not fixing it, thing can sit for a while sick of dramas (dont blame him). This week we decided to pull it apart and investigate.....
What we found was the welsh plug in the front of the head had somehow popped out
This is exactly how it was sitting behind the cover waiting nicely for us to remove it
Looking at the ghost marks in the head, the plug was installed crooked in the first place and was only "biting" on the very edge in one spot. We never replaced this plug when we built the engine as the head was reco'd by previous owner......oversight by us.
Fresh brass plug inside (correctly this time)
Video of start up after sitting unmoved for couple of months.....Poor little lifters havent had a drink for a while
http://i56.photobucket.com/albums/g188/nick81xd/Alans%20rb25%20engine/th_VIDEO0228_zpsd83mgvg1.mp4
Oddly enough when stripping down i found the inlet cam was a tooth forward of mark :wacko::wacko:. We have no idea how that has happened as it was checked few nights before the tune, We have a little bit more work to do before drivable but will have to check the tune AGAIN to see if it was tuned with the cam advanced......May drive like a completely different car and pick up some power somewhere in the map.
On a non engine related news. Owner ordered various front arms, a complete rear arm set and rear hub/knuckle assembly this week from GKTECH. So when those parts all arrive i will be documenting all of the work put into installing that kit. Time to stop messing around, playing games and get the car ready to be given a hard time at the track.
Edited by nick81xd
Haha. I only posted on this due to the fact that I'm in the middle of doing my rb25 neo gtx3582r. Mine will hopefully be sorted by next weekend. Dyno booked for Friday. Only going to run 20 to 22psi as bottom end is std and neo head still runs factory valves and springs.
  • 1 month later...
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
