Brought some Bosch 1000cc injectors ready to go.
Took a chance on a ebay top feed rail kit that turned up today and of course aint close to fitting. So back on the hunt for a top feed rail setup again.
try injectorsonline.com , they sold me a cheap rail for $100 to go with my xspurt 1000's, needed a return hole welded which didnt cost much to do..
that was a topfeed rail which fit my r33 with some machining of the spacers..
I think Plazmaman do a nice fuel rail now too? I ended up with a HKS item but swear i saw one from Plazmaman recently...
  • 1 month later...
TIME FOR A UPDATE.
Its been a very long time since anything has happened with the car.
With all the flooding going on around town kinda had more important thigns to take care of then car stuff. With everything back up and running the car went in for injectors and a tune........didnt go to plan.
I ordered a set of bosch 1000cc 11mm injectors and a SARD 11mm rail after the first rail didnt fit, Not thinking ripped the injectors out of bags and threw them into the bench tester to check flow rates, patterns etc. Not realiy paying attention but they had sent a set of 14mm injectors by mistake. So had to order some adapters to suit and wait.
In the mean time just been doing little touch up things. Remade the catch can breather hoses in 200 series braid to match the rest of the speedflow.
Car is booked in on the 18th of april for another shot at tuning. With any luck will have some results and Then its time for the owner to fill his pants when its on boost
Spot the mistake made by a person who isnt me
how it looks currently. slowly getting there making it look tidy
577318_10151507348226151_1198993693_n_zp
Very nice - what fuel are you going to be tuning this on? The 1000cc injectors aren't going to be big enough if you are going to be leaning on it hard on E85... a chap over in NZ made 470kw @ hubs on a similar engine setup in NZ on pump gas, so a huge amount of air can be flowed through those GTX35Rs on an RB25 built to suit :O
Going to just be pump 98 for now until E85 is availble in town. Yeh they wont allow much tuning but by the time E85 is here 2000cc injectors will be even cheaper so can just drop them in and go.
Plan is just see how it responds on pump fuel and wind boost in until its not safely possible.
Here's a workshop blog update from a similar setup doing a similar thing, be interesting to see how your results compare:
http://sthitec.blogspot.co.nz/2013/02/rb25with-gtx3582-turbo.html
Being hub dyno they show higher number but if it can manage 400kw on 85 on a roller dyno, I think the owner will be happy.
after all he's only used to just over a responsive 300hp......will be funny to watch his reaction first time it spins 3rd
Yeah the hub dyno reads higher than what you are used to - but make no mistake, 470kw on a Hub Dyno is still very big power ... that is well and truly enough to get a full weight R33 deep into the 10s with sticky tyres on BP98, I'd expect it to hit 400-420kw on a roller all other things being equal. I daren't even guess what it'd make on E85!
Without VCT that turbo was really quite laggy, though
  • 4 weeks later...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
