i have an auto N/A r33 , series 1
as far as i know the diff is standard
but what ive noticed is it refuses to throw singles?
with the car jacked up i spin a wheel and the other rotates the different way and it feels real tight
its never thrown one single ever , what kind of diff comes standard in these?
not a bad thing im just curious
cheers
https://www.sau.com.au/forums/topic/408328-r33-na-diffs/
from memory all N/a cars come stock with no LSD, some factory upgraded ones came with LSD. But dont quote me on that.
so if you jack your car up and turn the right wheel clockwise, the other side turns in the opposite direction???? that means its a standard lsd
if both turn in the same direction, it means its has a LSD
LSD= both wheels lock up under a certain amount of accelerated pressure
Stock= one will light up at a time, unless you are on a pretty even surface and going straight, it can light up both wheels if lucky.
SOME S2 GTST's came equipped with a ALSD's but very few, i dont think any S1 came with it tho
https://www.sau.com.au/forums/topic/408328-r33-na-diffs/#findComment-6519798
  • 2 months later...
Then it'll be a type s, easy way to tell look at the model code if it reads e-ecr it's a type s. if its just ecr it's not.
Mine has a LSD rear end in it from factory although I'm not sure of the Diff ratio in it.
https://www.sau.com.au/forums/topic/408328-r33-na-diffs/#findComment-6640901
This is incorrect, the extra E is for something else, fast will tell you if it's type s or not.
https://www.sau.com.au/forums/topic/408328-r33-na-diffs/#findComment-6643391
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
