Hey guys up for sale is my 1994 r32 gtr,
111,000 thousand ks serviced every 3-5 thousand ks, first owner from japan all new parts used
Ive had the car for over 1 year, and has been very relaible but I'm now looking to buy abother car to follow my carrer path of being a real estate agent, (a R32 gtr is not appropiate for that)
The car is very straight no damged rails etc!
Ive have performed some basic mods without being to harsh on the stock motor but being very affective!
Mods include
performace/ power
3.5inch fujitisbo catback, custom front pipe with dumps (car sounds awsome :D)
blitz panel filter (stock airbox)
garret 2860-7s
racepace cam gears
nistune computer
greddy profec b spec ebc
razo turbo timer
tuned safley atm making 295kw with injectors make around 320 or more
Other
KYB coilovers with HKS springs
Spats sway bar
Stero including herts speakers and kenwood headunit
Work xd9 rims 18x10 plus 18 wrapped in 265 dunop direnzas LOOKS PHAT
bad points.. roof of the car has fade (clearcoat) and a few small marks on the car (car is old) but however
the dash has no bubbles or cracks (wich is a common problem)
Car has been taken well care of but it must go :(
Asking price 19.5 ono (can supply rwc depending on price) may sell cheaper without wheels etc not really looking for swaps either
Location Melbourne Vic
here are a few pics of the car can take more and these photos are when the coilovers were NOT installed
thanks for looking guys
Sk
https://www.sau.com.au/forums/topic/408371-94-r32-gtr/
  • Replies 47
Posted Images
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
