Bc Br Coilovers On R34 Gtt
I really need coilovers and I've narrowed down to BC BR Coilovers from JustJap... Has anyone else got this on an R34 GTT?
I'm concerned about the ride quality as I do a lot of highway driving. Also Im looking at a camber kit later on. Is this suitable with the BC BR coilovers?
  • Replies 61
Hey mate,
I'm in the same boat as you, looking for coilovers. The BC ones look good, but was also going to ask if anyone has had any experience with the YSR Coilovers? http://www.yellowspeed.com.au/
They look like a decent unit, and can adjust the preload separately to the ride height, which is a big one for me. Also look to be fully rebuildable by an Australian company, which also interests me.
Anyone had any experience with them?
Cheers,
Shazza
The YSR ones seem to be very stiff. Like 12/8 rates. The BC ones are typically 8/6.
You can ask them to change the springs out when you order I believe. But you're right, they do seem to come with excessively harsh spring rates.
Not sure about the spring rates. The car is basically my daily driver but I do have plans to take it the drags soon.
Didnt look at YSR mate. Heard good reviews about the BC ones and at $1140 its a good deal I reckon.
http://www.justjap.c...623&cat=&page=8
If its a daily driver, from reading what others have done, it seems a 8kg F / 6kg R setup is good for dailying. The BCs look like a decent unit for their price, but I have heard adverse stories relating to the longevity of their design, and the comfort of their dampers. Some people have mentioned they can tend to be quite harsh on the street.
YSRs have a 33-way Damping against BCs 30-way.
YSRs have an aluminium upper mount vs BCs Rubber Upper Mount.
YSRs have adjustable camber tops as standard (Unsure of the BC ones? They look like they have?)
YSRs are $995 vs BCs $1140.
They seem to be very similar in design. They even look similar.
Adjustable camber tops not being a selling point for Skylines though.
If I were to buy YSRs, I'd probably opt for the rubber upper anyway. Much nicer than pillowballs for noise and harshness. Hardly impacts on performance.
Edited by GTSBoy
Yeah, i've always run Rubber upper myself for the noise factory. Sure, they flog out quicker, but they aren't that hard to replace. Might be a noob question, but why are the camber tops not a selling point? I'm guessing there is a better form of camber adjustment then the tops?
Cheers,
Shazza
The 8/6 BC's are on the soft side. In a 33GTST they are perfect for the road. If you are not going to do any track work, drop them down to 6/4 or something, iirc doesn't cost any extra. Just have to wait for them.
Whilst Skylines might have struts, they are not MacPherson struts. The Skyline suspension unit (coilover) is not a structural part of the suspension. On a Mac strut car, there is only the lower links (the control arm and radius rod) and the strut. Therefore, the location of the top of the strut is used to set the camber. Hence adjustable camber tops are required if you want to be able to change the camber at all. But Skylines have complete upper and lower arm sets at both ends of the car. You adjust camber by changing the length of any of the upper or lower arms (not that there's much adjustment stock, but adjustment can be added by putting in eccentric bushes or adjustable arms).
I had BC's in my last GTT, they were about the same stiffness as the King springs I took out of it. So not too harsh on the road at all.
They were the rubber top's
I love them & will be putting another set in my current GTT.
Should have just searched mate, this has been covered 11tybillion times. But anyway i have BC BR's in my 34, work fine, go stupid low etc. I did read through the threads and choose the BC's out of about 10 coilovers including teins, hks, and a couple of custom sets. Also spend the extra $150 and get the BR version over the cheaper one.
Don't go just jap! Also go for BC BR's
I think just jap sells them for about $1399.00
Save some dollars and go for Streettotrack.com
He has them for something like $1195.00
Delivered
IMO: 8/6 is track, 6/4 is street. I live with 8/6 but on bad roads its a bit shit.
WRT the amount of adjustments whether 30 or 33 makes no difference. Some of these cheapo coilovers the adjusters do bugger all anyways according to the shock dyno, in that many of the adjustment positions are the same level of dampening. Ie, its ricey.
+1 to BC's with rubber mount top.
8/6 are on the soft side ????? Maybe for a track only car running soft compound slicks.
6/4 is definitely firm enough for street. If you think you need anymore than 6kg/mm on the front then you have some super sticky poo tyres or are a poor driver. Federal RSR will just barely utilize a 6kg/mm front spring. I'd up the sway bars a fair bit before jumping to higher springs (actually I'd bump the rear spring up to 4.5kg/mm too).
 Share
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
