I am 16 living in SA and i own a 34 non turbo skyline, due to the fact i cant drive turbo..
i am trying to do it up and make it the best it can be, what things will i have to do to put a subaru momo steering wheel on it, also what should i do to give it a bit more power without being obvious so i can avoid getting defected, also what is legal height and where do i measure from
thanks guys
theres a pic of the car give me your thoughts on other things i can do too
https://www.sau.com.au/forums/topic/408396-need-advice/
Do nothing, spend nothing.
Drive it until you're allowed a turbo then sell it and buy a turbo.
In the mean time, take extra, extra, extra good care of it so you get max $$$ when you sell it.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515254
Yup & keep a log book (backed up by receipts) of all services :)
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515297
its 10cm from the lowest point of the car
Whats your budget for engine mods? Unless you have thousands then dont bother- Your dollar for power output is not worth it comapred to a turbo car.
But if you have the money to spend then extractors, exhaust, compression- Not sure what other really? Susspension, sway bars, good rubber and genral maint should be first on the agenda-
But yer.......look in the NA section mate- But like i said- if you have cash then you can do anything
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515933
The 3 steps to a better performance car:
1. Make it stop
Get the best brake setup you can, including slotted rotors, braided brake lines, high performance pads.
2. Make it handle
Fit lowered (NOT super-low) springs, good quality shock absorbers (I reckon Bilsteins are about the best going), upgrade sway bars, urethane bushes.
3. Make it go
N/A, you probably can't do much more than a set of extractors, maybe a slightly larger (3") exhaust system.
If you get the first 2 right, you often don't need the third.
And for goodness sake, learn to drive the damn thing. Nothing much beats a good quality advanced driving course. (Most driving schools only teach you how to get the licence, not how to actually drive)
Lastly, don't drive it like a dick - you are simply asking for the attention of the police.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6516061
leave as is, as you will need a RWC when you sell it if you mod too much it will just be a pain in the ass to get..
if you leave stock and look after it you will most likely make more from it than you would by modifying it being NA.
save all that $$ for gtr when your off your p's :D
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6516116
1. Make it stop
2. Make it handle
3. Make it go
3" on a NA 2.5L engine is just plain stupid, unless you want to let the cops 3 suburbs away know you are coming.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526488
that is only half the law. 100mm is the minimum ground clearance, that doesn't relate to how much you can legally lower a car.
(for qld anyway), when lowering a car you must maintain at least 2/3rds of the original suspension travel (measured between bump stop and metal stopper). plus the amount lowered must be the same front and rear. so you can't take a 4wd hilux and lower it to 100mm off the ground and expect it to be legal.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526584
nothing, i have owned my R34 25GT for 2 years now and have donenothing except buy original GTT model rims for an unbeatable price.
I got a year left on my Green Plates ! and most of my savings are going towards something
turbocharged !
Only dollars you should be putting towards it are maintenance costs (oils, rubber bearings, break pads ETC)
Edited by starwarz
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526643
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
