Couple Of Qs R32 Rb20
Christmas came early this year … titanium piping ready for installation … IMG_5349.mov
By drifter17a · Posted
I might have found it, it was the inlet clip from resorviour leaking bur unsure if that is because I did not put the clamp back on correctly ( fully on the groove) or it had moved/ had always being like that i moved the clamp and now doing more tests i pressurised the system to 30 psi ( hydrulic system can take way more by doing little search around 150-400psi) and seen fluid was pushed out from inlet clamp. See my ingenious way of doing now doing vacumme test. -
If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
