if your looking for a few more ponies a split front dump from c.e.s at brissie.... 29kw 4wd gain... sexy spool sound... get a good cat and magnaflow muffler....value for money + better fuel...and your a happy chappie :yes:
hmm ill have a look at the cost cos i'll need it shipped to melbourne...
so you think I should go for the CES Racing Systems R34GTT 3” (long in design) style turbo twin dump pipe picks up 16-20 kw @ wheels with (any) aftermarket exhaust system upgrade. M.S. Painted (black) item RRP $550.00 (comes with mounting bracket).
Upgraded polished (silver) ceramic coated item – coated both inside/outside pipework. (excellent thermal properties), reduced under bonnet temperatures RRP $750.00.
Worth the extra $200 when I was considering the JJR Stainless 3" Bellmouth Front/Dump Pipe was $200 total??
I'll vouch for the JJR bellmouth too - it was probably the first mod I did to my car (I bought it with a 3" cat-back already fitted), and it made a massive difference to the way the car responded to the throttle, especially in day-to-day driving.
i went with the c.e.s split pipe with full s/s system because 1. cause i had the cash at the time 2. i wanted a custom quality fabrication 3. i wanted more power 4. i wanted better fuel, i got all four....when i drove the car back from brissie i kept changing it in to nuetral cause i thought iy was in 2nd (auto)...and i keep saying it and you longtime forum members are probably sick of hearing it bit i'll say it again it sounds like ripping silk :yes:
SUS stainless low mount extractors + SUS split dump + SUS decat + 3" catback straight pipe + JUN spiral cannon = Flames !!
HKS Solid suction pipe + TRUST airinx pod + 14 psi = Ripping silk a new one.
:domokun:
Edited by Springsteen
So you noticed a difference in response, power and economy with the JJR?
I just got a hks hi-power cat back from jap delivered for 1k. Cat from jjr and dump from performance wise. Tot. $1650. I'll be fitting it myself. It should be a direct fit if you buy stagea specific.
Just fitted a JJR Dump and cat over the last few days.
My car has a 3" cat back of some type, HKS rear cannon so probably HKS.
Made it a noticably more pokey in the low to mid range.
Didnt make my car any louder or throatier.
