Constant Clicking From Fuel Pump Relay And Quiet Clicks Coil Packs When Pump Switched Off
hey guys need some urgent help, I've got an rb25 in my 180 it having issues getting it going to get it tuned
we've just gone and fitted up a new turbo, manifold and done an injector swap on my RB25, and while everything was pulled off i tidied up the wiring under the dash, it has a custom loom but in the initial wire up I forgot to add the unswitched power as we had troubles saving the map on the power fc last tune so i thought this may have been the cause, but now we've gone to power everyhting up to set the injector values before we start the car and the fuel pump relay is constantly clicking. I have the fuel pump neg on a switch so i can isolate that and when i do we can hear a feint clicking in the coil packs (disconnected the to check if it was).
I've now disconnected all the wires i had played with and checked the power wires to the eccs relay but it still happens,
If i check earth continuity at the relay i can get a beep on the multimeter on three pins, and there fore back at the fuse panel. could it be the relay has shit itself, as i though this shouldnt happen or with the power on will this happen.
If any one has any ideas just throw them in the ring, I don't have another computer (stock or fc) at the moment to check if it will work with that but i can't see that i would have damaged anything in the computer so this shouldn't be it. I've tried a couple of things but any other ideas will be welcomed,
Cheers
Nick
Happens when my battery is low. The power going through the relays is on the fence between keeping the relay switch on and off. I hear it at the relays near the ecu and fuel pump.
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
