Ok,
I will live to regret this but you gotta live for the moment!
I'm planning on hopefully building an RB30/26 setup for my Skyline so need to free up some coin.
I thought I''d list in on here if someone has a side project or may know someone into 200''s/Silvias.
I'm seeling my 58000km S14 Series II SR20DET engine that I was going to go in one of my Datsun 1200 Utes. It comes with the following-
Complete Engine
5 Speed Transmission
OS Giken Performance clutch (done around 15000kms)
Wiring loom
Factory computer
Power FC computer and controller.
New Stainless (sexy!) turbo manifold (and standard as well)
New Stainless dump pipe
New Maddat crossmember for Datsun 1200 and engine mounts (no Maddat trans mount, just standard S14 mount)
New manifold stud kit
Standard T28 Turbo
Braided oil/coolant lines for turbo
Tailshaft (for modifying to suit recipient vehicle).
I can't think if there is anything else.
I'm chasing around $4000 in total. All up it's cost me about $5500 (Engine and trans $3000, Power FC $1000, OS Giken $1000, extras $500.
The cheapest one on Ebay is $2500 with no trans, wiring, computer, etc, etc!
Feel free to ask any questions.
Engine $2200
Trans $500 dibs pending
Power FC $750 dibs pending
OS Giken Super Single Clutch $500
SR20 Wiring Loom $250
Standard Computer $150
T28 S/less Dump Pipe $80 dibs pending
Braided T28 Turbo lines $100
SR20DET Tailshaft $50
Intercooler $250
Semi flexible on some things (mainly for multiple items). It's all selling for a lot less than I bought them for individually.
Will be advertised elsewhere so first in best dressed.
  • 4 weeks later...
A few things sold. Open to offers on individual bits or the whole thing.
I'll also pay anyone here $150 as a finders fee if you put me in touch with anyone that buys the engine.
Engine $2200
Trans $500
Power FC $SOLD
T28 S/less Dump Pipe $SOLD
Braided T28 Turbo lines $SOLD
Intercooler $250
Cheers.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
