hello every one, im new to rb26's, I purchased my r32 gt-r last friday, i never intended on buying one but i am the happiest person now that i own one. The car has the following modifications
ENGINE
-Ross forged racing pistons
-Ndc race bearings
-Extended crank
-N1 oil pump
-R33 gtr N1 steel wheel turbos
-Aftermarket stainless down pipes
-3 inch cat back
-Mines ecu
-Trust front mount intercooler
-50mm stainless radiator
-New starter motor
-Clear timing cover
SUSPENSION
-ISC Coilovers
-Adjustable camber
-Caster arms
-Front and Rear strut braces
At the moment its running stock psi, ill be needing to buy a boost controller before i turn it up.
What im wanting to know
- i would like firstly make the engine as reliable as possible, the car isnt fitted with an air oil seperator so this will be required, i have also read about the mines baffle on the top of the engine and the baffle in the sump, what other oil modifcations will increase the life of my engine
- what sort of killowatt should require me to modifying and upgrading the head, at this point in time mine has only been machined and polished,
-I plan to track it in the future, how are the fuel systems, will i be required a surge tank and new pumps on the lower hp? what sort of horse power will require me to upgrade the injectors and rails?
-3rd to 4th in the gear box there is a crunch some times, is ti possible to fix this?
- also is there any way to check that it has the extended crank, im paranoid about this
sorry if these are stupid questions i have only really worked on rotaries before, i know how to use the search button but im not finding the answers i want
thank you
Edited by geetea-are
https://www.sau.com.au/forums/topic/408475-just-bought-a-r32-gt-r-need-advice/
  • Replies 52
Alot if people will say that the g4 is better, personally I don't really know but from experience I'm very happy with mine
Not sure what extended crank is :s do you mean extended sump?
I'd leave your head as it is for the time being
That crunch from 3 rd to 4th is a common thing, some people claim they fix it from using Redline gear oil..
Personally I had my box rebuilt with new syncros and a modification on 4th to stop it from crunching in the future
Depending on what sump and baffling you have, I like to fill my sump to around 6.5 liters to stop oil starvation during high G's. Though I do have an after market sump at home ready to be put in for future track work
Injectors ( correct me if I'm wrong here) usually make around the 270-280 mark on standard rail pressure
I'd change my fuel pump anyway ( my standard one got old and killed my last engine.
Also afm Max out at around 300rwkw, but if you get a Link g4 you get rid if them anyway
Hope this helps
mines ecu should be fine if u dont want to raise boost levels for time being.. all jap chipped ecus run rich anyways.. at the very least, get it on a dyno and check your afr's - $80 odd
there's a ton of info on the forum.. search is your friend.. rb26 dyno thread will show what others have done to achieve the results.. good luck and congrats on the car
To get the max of your current setup all you need is a new fuel pump, boost controller and a tune (Nistune or a full standalone ecu)
Seeing as the engine is a bit built just tell the tuner you choose to take it to where he thinks is safe
No idea what those turbos will go to but probably near 300kw, probably be limited by the injectors so yeah whatever is safe on those
If you want to run e85 in the future you should go for a high spec ecu so you can run an ethanol content sensor
i know of several cases where people with mines ecu's have grenaded motors while running stock boost.
Its not the AFR's that are the problem on mines ecu's, its the timing maps (which is why they generally make a car feel GREAT! that much timing brings it alive! but dangerously)
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
