  • Replies 48
  • 4 months later...
This thread has been really handy for information.
Does anyone know the cons of using a radiator with plastic end tanks? The Koyo items with aluminium core but plastic tanks are less than half the price of the full aluminium items but I can't seem to find much info on if plastic is really any good.
Must be ok up to a point - I haven't got an aftermarket radiator I just got a new stocker c/w plastic top and thrash it round the track only 310awkw but it doesn't get hot at all.
I'm only running 250rwkw and with the factory radiator it takes a fair few drift runs before it starts to heat up so I think it should be alright.
I think plastic will (in general) start to fail before alloy. My plastic eventually cracked around the neck.
This is true but are we talking about 1/2 years and failure or 5-10? The full aluminium ones are obviously better but for less than half the price if it will last for a decent period of time I'm happy to take that route
I paid 135$ for a Worley eBay radiator, so did ny mate. So far so good, even the welds are decent.
I just hit up their website and the products do look pretty good. They don't seem to be dealing on ebay anymore though.
They have 52mm and 42mm but looks like if you want the 52mm to fit a r33/34 GTst/GTT also need to change shroud as they have a combo deal for those. If you don't have to change the shroud the 52mm can be had for $140 crazy cheap
http://www.worleyautoparts.com.au/CustomerProduct/Index/4?Page=1&currentFilter=skyline
Edited by Marcus89
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
