  • Replies 85
Popular Days
fark. i get my head bitten off. i dont think you will be at the next cruise, yoi would have sold the gtr.
besides, what do you want from the thread? your kidding yourself if you are going to make a decision based on us. deep down inside youve already made your decision. and this is your way of venting your frustrations and wastinf your money.
i will call it wasting due to the fact that you have just built the car and now going to sell it.
fools and their money are soon parted
Well thanks to a few posts and pm's of the more helpful blokes on here who don't troll and continue making stupid jokes I will be there because I'm not selling up any time soon.
The whole time I was respectful and polite despite getting drilled by a bunch of half wits. Me buy a fast and furious car? Brother I've gone through more cars in the past 2 years than you have in your life, owned a track only car, pulled motors apart. I bet you couldn't even change your own intercooler lol
Closed.
This is the last warning to you Wastelanders.
We are utterly sick and tired of having to clean threads lately because some of you just cannot help but post piss and dribble all across the forum. I've already given a few of you more than one friendly warning now.
The next thread that goes off topic outside of the wasteland, you are all getting a month ban.
End of discussion.
Guest
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
