hey guys,
ive got a r33 s2 as a daily car, and my clutch is on its way out. ive found a second hand exedy heavy duty ceramic clutch for cheap, apparently it has %80 left, so near new from what i was told. or i could buy a new normal exedy heavy duty, both around the same price. i dont know much when it comes to clutches, so how can i make sure that there is actually %80 left (where do i look?). also which one do you guys reckon is better for me? my car atm makes 194rwkw cuz apparently this makes a difference?
https://www.sau.com.au/forums/topic/408509-which-clutch/
+1 buy new. Given the cost to install I don't think a second hand clutch is ever really worth it. And if you cant verify if it is truely 80% left, assume it isn't.
Have you driven an ceramic clutch before? Happy to have that in a daily?
https://www.sau.com.au/forums/topic/408509-which-clutch/#findComment-6517761
kinda, there are full faced ceramics or puk ceramics
For a daily with some thrashing, just get a decent organic plate with a decent pressure plate.
NPC make great clutches for the price, give them a call!
Their 10" kits are gold, the pedal is near stock, that when I installed it, I thought I broke something because it was so light
Instead of using the carbotic plate most of us guys use, go for the organic. Should be better/easier to drive.
Ceramic and carbotic plates are not that fun to drive as a daily (yes I am soft lol)
https://www.sau.com.au/forums/topic/408509-which-clutch/#findComment-6529245
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
